SeaFoam options.
Old Feb 9, 2005 | 01:52 PM
4-RUNNIN' FREAK's Avatar
SeaFoam options.
I need to know all places you can get the Seafoam into. I know oil/gas.
But I need to know what vacuum lines would get the stuff to where it needs to go. Is it just the brake boost and PCV?
I am doing this on a Buick, so it's all new to me under there. I need to know where I can and can't put the stuff just in case I can't find one choice. This was the first time I looked under that hood in a few years. I checked the air filter and id had probably ¼ inch of soot on top of the pleats.
Old Feb 9, 2005 | 02:00 PM
kevin444's Avatar
Any source that hooks up right after the throttle body. The Brake booster would be the easiest one to spot as long as it feeds all the cylinder you should be good.
Old Feb 9, 2005 | 02:03 PM
OK. Thank you much.
Old Feb 9, 2005 | 04:38 PM
Just did the third treatment, but it didn't stall after I put in ½ can so I stopped. The only time it stalled was when I would put my finger over the brake vacuum line as it sounded like it would stall.
This stuff + changing the air filter seems to have brought back tons of power on this Buick. It didn't smoke bad, just looked soome cars you would start on a cold day.
1 can in the gas
¾ in the oil
1¼ in the intake
Old Feb 9, 2005 | 04:41 PM
humanoid's Avatar
Originally Posted by 4-RUNNIN' FREAK
~ snipped
1 can in the gas
¾ in the oil
1¼ in the intake
Dude, that's a lot for the intake!
Old Feb 9, 2005 | 04:43 PM
It was over the course of three applications.
Old Feb 9, 2005 | 04:45 PM
kevin444's Avatar
The best way i would do it. Is let it injest it. When done suckin, turn off car and go back to it like in couple hrs are even overnight than start the car and gas it.
Old Feb 9, 2005 | 04:46 PM
humanoid's Avatar
Gotcha!
Old Feb 9, 2005 | 04:53 PM
I was reading a post on a (I think) Honda forum and it said to use it on the front and find a hose on the rear of the engine because it doesn't get to all the cylinders equally. I guess you can use left/right for transverse mounted engines. I have to look for it and see what you guys think bout it. Kinda makes sense, the liquid will fall into the front cylinders first and not really get to the back.
Old Feb 10, 2005 | 03:10 AM
Seven treatments total so far. Not much smoke anymore. Less than one minute of very light smoke.
The last 4 treatments were,
#4. Let it sit for 7 hours
5. Let sit for 1 hour
6. Poured Seafoam in and drove right away
7. Let sit 20 minutes.
urabus
Nov 10, 2015 07:38 PM
sanctfy
Sep 13, 2015 06:33 PM
Boomer8404
Sep 10, 2015 09:01 AM
accuracy
Aug 4, 2015 08:05 PM
jjccamis
Jul 9, 2015 04:00 PM
