sdastg1 style tire carrier?
Old May 18, 2004 | 11:00 AM
Mikronized's Avatar
I need some way to hold a 33x12.50 spare but I don't have the money for a whole new rear bumper/tire carrier right now
I was checking out this thread https://www.yotatech.com/forums/f2/new-rear-tire-carrier-pics-32607/ and I like the idea behind it..
but his version is a bit weak and prone to breakage...
what would be the very BEST way to build a tire carrier like this but have it be super strong besides just reinforcing his design?
also would it work to change the design from his to hold a hi-lift and a plate like so?
thanks guys
Old May 18, 2004 | 12:18 PM
shazaam's Avatar
ha ha .. this is great!
I dropped it off at the welder to get the reinforcements done. But it won't be done anytime soon. I don't need it for another 2 months or so.
good luck with this man!
Old May 18, 2004 | 12:26 PM
Mikronized's Avatar
hey thanks dude!
Keep all of us posted on what you end up doing with yours.
Old May 18, 2004 | 12:29 PM
shazaam's Avatar
yeah the guy said it would be about two weeks before he can get back to it. and I have to run the design by Brian (waskillywabbitt) first. But it should be a lot better.
I have some ideas for what your trying to do .. have to step out right now, but I'll post them a bit later
Old May 19, 2004 | 10:16 AM
Mikronized's Avatar
where you going to post those ideas?
Old May 19, 2004 | 10:41 AM
ilion's Avatar
I wonder if using a thick walled tubing and having it mandrel bent by a shop would work out better?
It seems to me that keeping the tubing solid and curved rather than welded at a joint might increase the material strength. Or, at least, remove the stress inherent in welding.
For instance, a one and a half (1 1/2") inch round tubing bent to shape with the tire mount welded on. You'll have to use your imagination to see a basic 'S' shaped carrier.
Of course, it would still have to be welded onto a 2" square tube to fit in the receiver...
:sigh:
Old May 19, 2004 | 12:40 PM
SEAN_at_TLT's Avatar
No matter what you are going to have a lot of weight spread out across a wide area supported by only a 2" wide mounting point located far below. This will act as a powerful lever no matter what you do to it. But if you build it strong it can be made to work okay for low speed off-road situations. I would hesitate to run it on road too often due to liabilities. It will also rattle more than standard swing away which are already known to rattle a lot. Until you can get a custom rear bumper it will make for a pretty good band-aid solution. Think of it like a hitch mounted bike rack with a couple of heavy duty bikes on it. Heck you might even be able to modify one of those to work for you. A 4 bike rack will easily carry 150lbs. If you can find a cheap one used that might be the ticket. Some of them even swing out to the side.
Old May 19, 2004 | 12:55 PM
Mikronized's Avatar
I see what you are saying about the weight, I figured I would weld like a ring to the top and use some sort of strap to connect it to the roof rack that way that top leverage isn't there.
like this:
(yes I know the side view looks like a Xterra and the back looks like a jeep)
would that work?
Old May 19, 2004 | 01:03 PM
I took your well engineered CAD drawings and ran stress analysis on them. This is what I came up with. It looks like you have a .08% failure rate with the straps attached and a 17.84% failure rate without them. So i'd say...yup that'll work
-Sean
Old May 19, 2004 | 01:12 PM
Mikronized's Avatar
ha ha.. cool.
glad you could run that test for me
Old May 19, 2004 | 05:41 PM
ravencr's Avatar
I'm going to be doing a version of this eventually too, but mine will fold down to the side.
Chris
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
ia02
Aug 20, 2015 11:04 AM
4x4-runner
Aug 3, 2015 07:14 PM
defrag4
Jul 31, 2015 10:50 AM
