Rotors!
Old Oct 20, 2004 | 03:12 PM
benzim's Avatar
Rotors!
All right all you gurus...
I got the steering wheel vibration... time to replace the rotors (or so I believe...) is it worth it to go with slotted/vented rotors? Do they make that much of a difference... or should I save some cash and go stock?
Any hints?
Old Oct 20, 2004 | 03:14 PM
jimbo74's Avatar
what is your truck mainly used for? i ask this because there is a whole brake rotor theory thing
Old Oct 20, 2004 | 03:22 PM
bike4miles's Avatar
Well, slotted rotors are an improvement, although I don't know how much of one and I have always been a believer in fixing things so they are better than new so I would go for it.
Old Oct 20, 2004 | 03:24 PM
rimpainter.com's Avatar
I just went with Autozone rotors with a 1 year warranty and PF pads. My brakes have never been better.
Old Oct 20, 2004 | 03:26 PM
superjoe83's Avatar
if you want to go with "performance" rotors, go with just a slotted style, not cross drilled, Ive heard too many horror stories of cross drilled rotors cracking at the holes and coming apart catastrophically
Old Oct 20, 2004 | 05:35 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
You can get the Brembo OEM replacement rotors for about $45 each on-line. They seem to hold up better than the stock rotors. I've heard that slotted rotors can wear your pads prematurely.
Old Oct 20, 2004 | 05:45 PM
SkyRat's Avatar
When my fronts started vibrating, I went with Powerslot Rotors (slotted, not drilled) from Performance Products (since they are 10 minutes away) and got free pads. They stop much better than OEM. Very happy.
Old Oct 20, 2004 | 06:30 PM
k-bomb's Avatar
I recommend the powerslots. We put them on a lot of the big american SUV's at the brake shop I work at. They do work much better than OE. Just be sure to use a severe duty pad instead of a softer pad material. It will chew up a softer pad material. The powerslots can still warp and cause pulsation, but it is rare. Be sure that the rear brakes are adjusted properly and doing their small share of the braking to prevent future warpage of the front rotors. That's my two cents.
Old Oct 20, 2004 | 07:03 PM
stevrock's Avatar
Did you check your aliment and balance? What about for broken belts in your tires? Here these are major problems, our roads are garbage.
Old Oct 20, 2004 | 07:04 PM
GregStevens's Avatar
Actually, it depends on how the holes are placed in the rotors that makes them susceptible to cracking. If the rotors are actually DRILLED after casting, then they are far more likely to crack over time. However, if the rotors have CAST-IN holes, they are far less likely to crack. Big difference. All race cars have rotors with holes, which should tell you something...
But, will they 'really' effect the performance on a Runner? I really can't imagine you would ever notice a difference. Drilling/slotting is really a race application. When I used to race my S2000, I had slotted/drilled rotors...I can honestly say that in the thousands of miles at lots of racetracks, I never once felt a difference with slots/holes. Perhaps they ran a bit cooler and had better heat dispersal, but this never translated into faster laptimes. And the courses I ran were very hard on brakes.
I replaced my rotors/calipers all with Bendix stuff...basically remanufactured calipers and new rotors. Stops on a dime and gives 9 cents back in change.
The bottom line, I wouldn't pay one red cent for rotors with holes/slots more than those without for a Runner. You will never, ever notice a difference in performance. Only a lighter wallet...
Just my dos centavos....
Old Oct 21, 2004 | 04:15 AM
TDiddy's Avatar
What did they charge you, if you don't mind me asking?
Old Oct 21, 2004 | 04:33 AM
Ilovemountains's Avatar
Exclamation Brembos for $30!!!!!!
Good morning, I got my Brembos from these guys 2 weeks ago for $90 shipped for the pair, you will not find a better deal on rotors, I looked!!!!!!!!
http://www.importrp.com/left.php?sub...el=251&year=19
Old Oct 21, 2004 | 04:50 AM
Autozone online (in which the warranty applies to any store) ran me about $170 shipped for everything. Rotors and pads.
Well worth it. The rotor shimee was driving me nuts!
Old Oct 21, 2004 | 04:53 AM
TDiddy's Avatar
yeah, I have the shimmy too...gotta do something about it!
Old Oct 21, 2004 | 10:32 AM
3.4v6's Avatar
i have no complaints about slotted rotors .. they are treatin me well
Old Oct 21, 2004 | 11:06 AM
Amir904's Avatar
the drilled rotors affect the structural integrity... i dont know about the slotted, i guess they help in heat dissipation. i just bought brembo rotors from tire rack, they should be in by tomorrow. i will also be installing PF pads.
Old Oct 21, 2004 | 11:14 AM
PirateFins's Avatar
Mine are driving me nuts also. The only problem is they are only 6 months old.
I needed to do alot of hard/long braking on a mountain while the bed was loaded down (driving behind a semi, so I couldn't do any coasting).
Can the rotors be turned while on the truck? I don't feel like having to tear down my front hubs in order to have them turned?
Old Oct 21, 2004 | 11:50 AM
Amir904's Avatar
how do i adjust the rear brakes?
Old Oct 21, 2004 | 12:13 PM
fiveofeen's Avatar
i just did a major disc upgrade on my mustang and stayed with reg rotors. i wouldnt spend the extra cash myself. ˟˟˟˟ my 4runner has 4 piston calipers up front already! it doesnt need any extra help.
ladybugRC
458
Aug 21, 2020 10:41 AM
Kamaloha
Oct 16, 2015 05:13 PM
the_supernerd
Oct 1, 2015 09:20 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Toys4parts
Sep 26, 2015 01:56 PM
