Resistor Mod?
Old Aug 27, 2003 | 08:23 PM
Albuquerque Jim's Avatar
Resistor Mod?
Resistor Mod
What is this really?
I am not a total idiot when it comes to trucks, but I haven't spent any time with piggy back computers and such yet.
Can someone fill me in on the validity of this mod?
Old Aug 27, 2003 | 09:05 PM
Yoter's Avatar
Guest
Never heard of this mod on any vehicle. It seems fishy that under tools needed it states only a "piece" of electrical tape and yourself. No wire cutters, wire connectors, soldering iron ect ect.........? How so? I think there is something off here. And only for $4? Hmmm, im gonna pass and spend that $4 on some decal kit that will make me go faster. By the way that decal remark is a joke. I felt I better say joke so I dont get someone asking "how do decals make you go faster"? (Rant Mode Off)
Old Aug 27, 2003 | 09:09 PM
turboale's Avatar
Looks too good to be true to mee too...
Old Aug 28, 2003 | 05:51 AM
szf2's Avatar
Never heard of that before. Did some research and it looks like IAT Sensor = Intake Air Temperature Sensor. So the resistor must decrease some signal from the AFM or MAF. Maybe this makes the ECU think the air coming in is colder than it really is and the ECU responds with more fuel? Just guessing really. Maybe someone who knows more about the functioning of the ECU will chime in.
Old Aug 28, 2003 | 07:17 AM
WT's Avatar
WT
Think this might answer a few questions. I think a few people here have done this mod.
http://www.midiwall.com/4Runner/ect.html
Old Aug 28, 2003 | 09:55 AM
MTL_4runner's Avatar
All you are doing with the mod is adjusting the output from one of the sensors.
It does work but I doubt 15 HP worth.
May help get rid of a pinging condition (due to leanout) if you have one.
Old Aug 28, 2003 | 01:14 PM
Yoter's Avatar
Guest
Post Misconceptions of the EbayMod
I like Dr. Zs info on this & will seriously look into his over the EBay ad. The ad states that you only need a piece of electrical tape (LOL), no tools,no wire,no conectors,no soldering eq.,and one I am wondering about being no damage to your eng.. If it alters your timing and allows more fuel to be delivered couldnt that overload the fuel injectors? This EBay ad may have stole the idea from someone not saying they did but it lacks the proper info on the mod. Dr. Z goes above and beyond explaining it all. Maybe that a deal on the resistor but the facts are not there for me to believe.
Old Aug 29, 2003 | 05:40 AM
You should really have a potentiometer (like Dr Z suggests) rather than a single resistor. You are trying to fine tune the output of the sensor for best performance and I guarantee a single resistor won't work unless you get VERY lucky.
Old Aug 29, 2003 | 06:23 AM
ALBPM's Avatar
I agree!!!!
Better consult with the Dr. first.
Old Aug 29, 2003 | 06:30 AM
rimpainter.com's Avatar
Is there a Dr in the house?
Where you at Galen?
Old Aug 29, 2003 | 08:31 AM
Dr. Zhivago's Avatar
Away
Where you at Galen?
I'm here.
As for modding the IAT on our trucks: On some vehicles, changing the IAT does make a big enough difference to warrant messing around with it. What the resistor does is fool the ECU into thinking the Intake Air is cooler than it is, by increasing the circuit resistance, which can affect timing advance and fuel enrichment.
However, it does NOTHING for performance on the 5VZ-FE. I am speaking from experience. I had done the IAT mod on my truck with a 10K Ohm Potentiometer to see if there was any performance to be gained from it. There wasn't. Using my BR-2, I analyzed the Timing and Fuel Trim curves and there are no changes made to either of these parameters when modifying the IAT sensor circuit. With a 10K Ohm pot on these engines, you can bring the "Perceived" IAT down to 5 Degrees F, so you can be assured that I tested the full gamut of temperature ranges.
On the other hand, the ECT mod does improve low end and midrange torque and responsiveness. Mind, you it's not an earth-shattering difference, but it is noticeable. WOT is affected as well, but not to a great extent as the WOT maps are pretty set and fairly rich on a NA engine. You need a piggy-back to mess with those so that performance is noticeably affected.
All those E-Bay ads assume one resistor value for ALL cars wil suffice. That's BS. I hope this clears things up.
Peace!
G
Old Aug 29, 2003 | 12:50 PM
Originally posted by Dr. Zhivago
I'm here.
However, it does NOTHING for performance on the 5VZ-FE. I am speaking from experience.G
I am not surprised, seems like the best you could do is to just richen the mixture and maybe eliminate any lean spots in the curve......I wouldn't expect it to make any more power on a properly tuned engine though. I would also think the ECU will be fighting you on the long term fuel trim....maybe not.
TheBFA
Feb 15, 2020 06:55 AM
punks_is_4x4
May 31, 2016 06:03 AM
voiddweller
53
Feb 1, 2016 05:46 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
