replacing fluids, need advice
I have a 96 4runner 2.7 4cyl
What should I use for the rear end?
What should I use for the trans?
What should I use for the engine?
Just want to get some thoughts before I change them all this weekend.
Thnx,
T
Thnx,
T
You could convert it all over to synthetics if you wanted to, but I'm not sure how much money you're wanting to spend.
Check out this site: http://www.top4runners.com/ja/synthetic.html
Thanks for the suggestions guys, and thanks for being not so funny scuba(I already had the manufacturer suggestions but this is where the offroaders gather and I wanted their advice). I checked with the drive train shops where I know people and I'm going with royal purple even though its a bit much on the dollar side I figure its worth trying it at least once. We'll see what happens!
I'm running Mobil One 75/90 gear lube in transfer case & both differentials...seems to work great and have had no problems with LS in rear. I'm running Mobil One 10w30 in the crankcase, but in the transmission case I'm running B&G, because I was due for a tranny flush and that's what the shop had on hand...supposed to be good stuff though.
Been running all of the above, except B&G in tranny, for past 2k miles...smooth and cool. I went with Mobil One because it seemed a little hard to get Amsoil on short notice.
skoti89
Jul 8, 2015 12:05 AM
Vargntucson
Jul 4, 2015 12:15 PM
