Replacing Coil Boots part of PM?
Hi everyone!
I did not find anything browsing Toyota scheduled maintenance schedules, nor forum threads, so want to ask:
When is everyone changing their coil boots? Every spark plug change? Every-other? Not until misfiring starts? Etc?
I just hit 120K miles and I want to stay up on my preventative maintenance. Since our 4Runners do not have distributor caps/rotors (which I normally would change when changing spark plugs), I was not sure if I should be changing the coil boots at spark plug intervals or not...
Thanks!
James
1997 4Runner SR5, 4X4, Manual
Thanks!
James
I've never heard anything called a coil boot. If you're talking about the spark plug wire, which runs from the coil pack to the spark plug, then yes, replace them when you replace the plugs.
Wait until you have a coil go bad, then replace the coil and the boot at the same time. No need to replace something that is not broke.
If you are looking to spend $$$ on PM for ignition, plugs and wires are a good start.
Now, just gotta save up some $$ for new OME suspension and tires!
Thanks for the input!
James
'97 SR5 4x4, 5-Sp, tons of 'Limited' & other dealer-installed options, Anthracite Metallic & luvin' it!
88Toy
7
Jun 17, 2015 09:40 AM
scotts93
10
Jul 30, 2002 08:24 AM
