Removing Locking Lugnuts - Without the Key
Old Jun 5, 2006 | 05:08 PM
DoubleZero4x4's Avatar
Had an interesting experience today. The wife's truck was getting new tires and there was no key for the locking lug nuts on the truck. Well...F... now what!?!?!?!
A quick google search and I found this idea from a Corvette forum...
You need to get a 12 point socket that barely fits and...
Drive it on tightly, 4-5 decent wacks with a ball pean hammer will do the trick. You have to make sure the slots in the socket bite into the lug nut. Use a manual lug wrench - not a pneumatic tool to loosen the lug. Slow even torque is the ticket. When loose the lug will be stuck tightly in the socket. Place socket in a vice and drive ilug nut out with a drift punch and repeat three more times. Then throw the stupid locks away and get some standard lugs from the dealer in town.
I can tell you that it worked!!! I pounded on a 19mm socket and used a breaker bar to turn it slowly. Worked like a charm. Once the locking lugs were loose I simply pulled up and down slightly so that the socket would loosen up on the lug. Went to the stealership and picked up 4 news lug nuts and tossed the locking ones.
Old Jun 5, 2006 | 05:44 PM
Elton's Avatar
nice thats good info should make it a sticky
Old Jun 5, 2006 | 06:35 PM
I was thinking at least a tech write-up.
Old Jun 5, 2006 | 08:59 PM
sschaefer3's Avatar
I have welded a bolt on and buzzed them right off, but that is a good trick if you don't have a welding machine handy.
Which most people will not.
Old Jun 5, 2006 | 10:13 PM
HUTCHSTACO's Avatar
or head to discount tire to have them pull em off for 20 bucks
Old Jun 6, 2006 | 10:22 AM
surf4runner's Avatar
i had the type w/ the puzzle key and smooth outside and a socket didnt work. so i used a BFH and cold chisel to loosen. only scratched 1 wheel.
Old Jun 6, 2006 | 10:31 AM
mt_goat's Avatar
If they are Toyota factory locks the dealer will sell you a key for about $20.
okamikai
Apr 30, 2018 10:19 PM
TDonkey
Jul 26, 2015 10:14 AM
RustBucket
Jul 24, 2015 04:46 AM
Hamonacracker
Jul 17, 2015 08:33 AM
icentropy
Jul 14, 2015 10:23 AM
