removing flywheel bolts!!!!!! (arghhh)
Old Feb 21, 2005 | 02:10 PM
TechWrench's Avatar
Well, if the bolt direction isn't an issue, then all that remains is to use one of the methods mentioned to secure the crank so it doesn't turn and use a long enough handle to overcome the bolt torque. Which brings up another point. When you get ready to put it all back together, make sure you tighten the bolt to the correct torque setting. It was initially tightened to that degree for a reason.
Old Feb 21, 2005 | 05:29 PM
needayota's Avatar
are there torque wrenchs that go to 190 ft/lb?
i dont think mine does.
Old Feb 22, 2005 | 04:49 AM
MTL_4runner's Avatar
Yes, but I'd just rent one instead of buying it.
Don't forget to loctite the threads when installing it.
Old Feb 22, 2005 | 05:34 AM
needayota's Avatar
ok.
thanks for all your help man
Old Feb 22, 2005 | 09:16 PM
  #25
p5150's Avatar
i dont think the Toyota manual recommends loctite.
Old Feb 23, 2005 | 04:18 AM
  #26
You always want to loctite anything in a critical application (crank pulley, flywheel, brakes, etc).
There is no damage caused by doing so and it adds extra insurance that it will not come apart on accident.
Just be sure to select the correct loctite for that particular application.
Old May 6, 2019 | 02:46 PM
  #27
rmjones's Avatar
Flywheel bolt thread direction
What is the direction for the removal of the Flywheel bolts for 2007 toyata hilux, every post just seems to skip that point.
Old May 7, 2019 | 06:32 AM
  #28
millball's Avatar
Rightie tightie, leftie loosie. Only in certain rare instances are left hand threads ever used.
Sep 4, 2015 09:27 AM
accuracy
Aug 6, 2015 12:32 PM
TJWilly
Jul 31, 2015 02:05 PM
TransAmBandit
Jul 28, 2015 11:30 PM
KBar
Jul 13, 2015 06:01 PM
