Rear Window no worky
Old Apr 15, 2003 | 12:46 PM
bbarggren's Avatar
Unhappy Rear Window no worky
ALL...
Has anyone here had any experience with the power rear window going out in your runner? Mine just plain quit working the other day. I have tried both the inside switch, and the key in the tailgate, but niether work. I checked every fuse I could find with no luck. Is there a secret handshake with these things, or are they like the infamous Toyota power antennas? (ie-New Motor)
Any ideas about what it should cost to fix???
Anyone know a good source for a new/rebuilt electric motor (if that's what it is)??
Thank You
1996 4Runner SR5
3.4L V6, 5-Speed Manual, 4WD
After 3500 miles of record keeping, still averaging 21.1 MPG Combined City/Hwy. woo hoo.
Old Apr 15, 2003 | 12:49 PM
mtnfreak's Avatar
Betcha it's just a loose or broken wire. Pull off the inside cover of the tailgate and see if you're still getting power.
Old Apr 15, 2003 | 12:51 PM
delboy's Avatar
More like infamous regulators. Think they normally only last a few years. Heard of one guy who got three of them in 5 years!
Not sure about replacement price etc.
Old Apr 15, 2003 | 01:02 PM
Corey's Avatar
Co-Founder/Administrator
I am not familiar with the 3rd gens, but us 2nd genners have a rear window lockout button on the console.
http://pnw4runners.net/tando/cb_mic.jpg
If that button is deployed, the key or switch won't open the rear window, or at least it won't from inside.
I have not tested it to see if I can raise or lower it with the key when that button is pushed.
Someone may have pushed your button by accident.
I have done that to mine when I clean the interior.
Old Apr 15, 2003 | 02:22 PM
Victor's Avatar
Mine will still work with the key in the tailgate with that button pushed in. I forget sometimes when I hit that button to keep the kids from driving me nuts with the windows that the tailgate window won't work either. I wish Toyota wouldn't have wired that one in with the other windows.
Old Apr 15, 2003 | 03:18 PM
az4x4runner's Avatar
I don't have that button..?
Old Apr 15, 2003 | 03:20 PM
Victor's Avatar
Are you sure? It's on the driver side door - one of the front 2 buttons. Labeled window lock or something.
Old Apr 15, 2003 | 03:21 PM
Oh ok, I do have that button, but not the one Corey shows, the only thing I've got down there is the one to roll the back window up and down.. and 2 little things to hold change.
Old Apr 15, 2003 | 03:24 PM
Victor's Avatar
If the window lock button is down you won't be able to use the switch in the center console. It will still work if you use your key in the tailgate. Very cooky way to wire it if you ask me but what do I know. Since only the front passenger and driver can easily reach the switch I don't see the point of locking it out from the driver's panel.
Old Apr 15, 2003 | 03:28 PM
Yeah, I find that kind of strange too...
sorry for taking this thread kind of off the original subject..
Old Apr 15, 2003 | 03:33 PM
Victor's Avatar
There is a relay in the tailgate. I've seen them on sale on Ebay pulled from trucks. I haven't heard of them often going out but they do. Check the wiring to your switch and check all the connections that run to the tailgate. Hopefully it is something as simple as a broken ground wire or the relay wiring harness is loose.
I'm not knowledgable on the procedure to test the relay to see if the problem is the relay or the electric motor.
Old Apr 15, 2003 | 04:47 PM
95_4X4Runner's Avatar
Also, I heard that there's an interlock for the window involving the wiper. If it isn't parked correctly, the window won't work, which makes sense.
I'm guilty of thinking my rear window didn't work, because of the lock out switch Corey mentioned....
Old Apr 15, 2003 | 04:51 PM
rpeAMP's Avatar
I had that exact same problem...I thought my rear window had stopped working, however the wiper on top wasn't seated correctly, therefore locking out window operation both from the key and the switch in the front.
Old Apr 17, 2003 | 01:55 PM
bbarggren's Avatar
Thanks for the ideas guys....I will DEFINITELY try the rear wiper thing when I leave work today. That would make sense, as I have not used the rear wiper since the window stopped working, and I had it at the carwash right before this started happening. Will let you know if it works.
Old Apr 17, 2003 | 03:04 PM
PhxTRDRunner's Avatar
I have been guilty of pushing the "lock" button on accident too..hehe surely makes you pull your hair out for a little bit.
Great diagnosis everyone...
Old Apr 18, 2003 | 11:12 AM
bbarggren's Avatar
Talking User Error
All...
Thank you all very much for your advice on this rear window "problem". I now feel like a big dumb ASS, but my window is happy again. I had gone to the carwash, and even though the rear wiper seemed to be properly seated, it must have been moved just enough to trip the sensor. All I had to do was turn the rear wiper on and off once, and it all works again.
Old Apr 29, 2003 | 05:49 PM
TDiddy's Avatar
I did the same thing today. I must have hit the lockout button accidentally, and when the rear window wouldn't go down I was furious. I didn't even think about the switch until I got home from work and started going through the Haynes manual.
A part in Chapter 11 talks about continuity and the lockout switch, and it was like a light bulb suddenly went off. I went back out to the 4R, and sure enough, the switch was down!
Jun 1, 2021 01:51 PM
RustBucket
Jul 24, 2015 04:46 AM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
coryc85
Jul 6, 2015 04:07 AM
