Rear Window
Old Feb 5, 2003 | 08:20 AM
tpg013's Avatar
Junior Member
Rear Window
The rear window on my '94 Runner has been operating very slowly of late. I opend up the tailgat and greased everything up, but not much difference. It seems to go fine until in meets sides of the frams then it slows to a crawl and sometimes stops. Any ideas? Could it be the motor?
Old Feb 5, 2003 | 09:26 AM
kerrs's Avatar
Did you grease the runners on the bottom of the window?
Also check to see if the assister spring has broken.
I can post some pics if you want. I did mine last week
Kerr
Old Feb 5, 2003 | 09:42 AM
BTOWN4RUNNER's Avatar
I noticed that mine does that too, mostly in the colder weather that we are having. I am guessing that is has something to do with the motor being cold and all. Other than greasing and lubing it up really well, I don't know what else it could be! :fireman:
Old Feb 5, 2003 | 09:45 AM
tpg013's Avatar
Junior Member
Kerrs, could youi please post some pictures? It would be helpful. thanks.
Old Feb 5, 2003 | 09:58 AM
kerrs's Avatar
This is where to grease
And
The spring to look for is on the inside of the mechansim where the blob of white grease (left side) on the second pic.
The runners always rust up and cause loads of problems, some times they even fall of.
Regards
Kerr
Old Feb 5, 2003 | 12:59 PM
tpg013's Avatar
Junior Member
Thanks for the pix. How'd you get the window to move with the gate down?
Old Feb 5, 2003 | 01:16 PM
kerrs's Avatar
where the gate locks you will see two latches one either side.
press a srcewdriver in each one so that the gate thinks it is shut, then you can either use the key or the switch in the cab.
if you want pics I'll take some
Kerr
Old Feb 6, 2003 | 05:15 AM
tpg013's Avatar
Junior Member
I tried that on mine but no luck. All I got when i turned the key was a beeping noise. I'll have to try again.
Old Feb 6, 2003 | 11:53 AM
kerrs's Avatar
make sure you are closing the latches all the way, they click once then press them again
Kerr
Old Feb 20, 2003 | 01:07 AM
Arik's Avatar
I have the same problem (my window stoprd finaly and now i can hear it , but the window stays up.
By the way, any idea how can i open the rear door while the window is closed ?
Jun 1, 2021 01:51 PM
RustBucket
Jul 24, 2015 04:46 AM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
coryc85
Jul 6, 2015 04:07 AM
