Rear window
Old Jan 1, 2005 | 10:46 PM
92foreruner's Avatar
Rear window
I have 92 4runner and just had the rear regulator replaced. The guy at the body shop said to keep the gears clean of gunk. But never said how or what to use to clean it and the relube it if need be..I was wondering if any of you had experince with this?
Old Jan 2, 2005 | 11:23 AM
jasonbrink's Avatar
I'll give ya a bump on this one....I'm having the same issues
Old Jan 2, 2005 | 11:31 AM
Yoter's Avatar
Guest
Do you have a grease gun? That what I use and it seems to work.
Old Jan 2, 2005 | 04:28 PM
leebee's Avatar
you can always pick up a can of white lithium grease, i comes in a spray can with the little extension straw like wd-40.
lee
Old Jan 2, 2005 | 04:40 PM
Godzilla's Avatar
What does the rear window regulator do? and what were the signs that indicated it needed to be replaced?
Old Jan 2, 2005 | 10:42 PM
Yoter's Avatar
Guest
The regulator acts as an elevator for the window to ride on. Its like a pair of scissors in the effect of how it operates. A bad one in some peoples opinions is a broken one that is cracked or tweaked but if you have the right tools you can fix it up. I think they mainly go bad when they lack lube and stop working due to the pressure and bend or break.
Old Jan 2, 2005 | 11:13 PM
nyceride's Avatar
Just use white grease (not lithium grease) or multi purpose grease. Grease up the teeth on the regulator and the window tracks (just the bottom one). I used the white lithium grease and its a pain to clean when you finally realize that you have to fix or replace a part in there.
Old Jan 4, 2005 | 01:02 PM
jasonbrink's Avatar
Are there any write-ups on taking the tailgate apart, what/where to lube etc?
I always learn more by pictures than words so I hope there is a write-up.
Thanks,
Jason
Old Jan 4, 2005 | 08:44 PM
nyceride's Avatar
Well I thought I explained it ok....but look at this site....page 6 is a perfect picture that will answer all your questions on lubing up the window.....and your welcome
http://personal.utulsa.edu/~nathan-b.../3frontdoo.pdf
Old Jan 4, 2005 | 11:43 PM
bike4miles's Avatar
I just pop the carpet board off and use an oil can. This seems to be the cleanest way to go about it. I lube the gears, the conector arms, and anything else that moves.
Jun 1, 2021 01:51 PM
RustBucket
Jul 24, 2015 04:46 AM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
coryc85
Jul 6, 2015 04:07 AM
