Rear Axle
Old Oct 1, 2009 | 10:16 AM
Canadian Bacon's Avatar
Rear Axle
I sprung a rear axle and thus have to change out the seal. I have everything taken apart, but I need to take it to a shop to get the seal pressed out. I just phoned my local Toyota dealer and they recommended changing the bearing, all the seals, clip etc. because oil would have gotten through the bearing which would eventually cause it to fail. Is this a load of crap?
So should I just get the seal changed, or the whole deal?
Thanks.
Old Oct 1, 2009 | 10:33 AM
874runnersr5's Avatar
I just did this, what seal is leaking? The one on the housing? or the one on the rear axle shaft?
Old Oct 1, 2009 | 10:40 AM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
The axle seal can be pulled out with a seal puller IIRC
Old Oct 1, 2009 | 10:44 AM
JFCruiser's Avatar
shouldnt be that hard now all you need is the parts and im pretty sure you can get it here at a really good price like i did
http://toyotapartszone.com
they even have hot spots to help you locate the exact part and diagrams to help you install it
LOVE THIS WEBSITE
Old Oct 1, 2009 | 10:53 AM
I have a seal puller, so I can get at the inner seal. I'm talking about the outer seal by the bearing, the one on the axle shaft.
Regardless, I know I can get just the seal changed, but should I also change the bearing due to potential oil damage. Way I look at it, is pay for it now, instead of paying for it later. I rather have my truck in perfect working order seeing as the cold is coming fast. It isn't fun working in the garage once the mercury drops.
Thanks.
Old Oct 1, 2009 | 11:43 AM
Might as well, your going to need a press to get the new bearing on
Old Oct 1, 2009 | 12:32 PM
nc994run's Avatar
In that case, go ahead and have them do it all at once
Old Oct 1, 2009 | 12:35 PM
That's what I was thinking. Thanks. Now if I can just get through to the servicing guy at Toyota. They must be really busy with everyone getting ready for winter. There was already frost on my windows last night.
Thanks.
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
yourrealdad
Jul 21, 2015 11:13 AM
toyoda8488
Jul 5, 2015 10:18 PM
