Quick Help: Nut Size for 96 Runner Hub Nut?
Old Apr 15, 2004 | 09:39 PM
EDGE's Avatar
I'm doing a rotor install for a Toyota 4Runner (1996) and need to know the size of the hub nut right below the dust cover. Anyone, please let me know asap!
This is for someone on another board so TIA
Old Apr 15, 2004 | 09:47 PM
WATRD's Avatar
Toyota's have two sizes, a 36mm or a 54mm.
Old Apr 15, 2004 | 09:54 PM
EDGE's Avatar
How do you know which size you have or it is either or, thanks for the fast responce
Old Apr 15, 2004 | 10:03 PM
WATRD's Avatar
Pull off the dust cover and measure it. If it's close to one or the other, it's that one. The 36mm one is about the size of a half dollar coin, the other one is considerably larger.
Were it a Tacoma of that year, it would be a 36mm, but since it's a 4Runner, while I suspect it's still a 36mm, I can't say for certain. The differences between 4Runner's and Tacoma's catch me off balance from time to time.
Old Apr 15, 2004 | 10:05 PM
EDGE's Avatar
Thanks man, your truck looks bitchin in the avatar
Old Apr 15, 2004 | 10:23 PM
WATRD's Avatar
Thanks! I use a few photos from that series as the main images on my web site. I was fortunate to have several photographers in good positions when I went through that stretch
Old Apr 16, 2004 | 04:36 AM
CTB's Avatar
CTB
I know the hub nut is 54MM for 2nd Gen's, but that may not really help you. Are you doing this on a 2WD 4Runner? On a 3rd Gen 4WD, I don't think you should have to remove a hub nut to remove the rotor.
Old Apr 16, 2004 | 04:47 AM
SLC Punk's Avatar
Sorry its still early in the morning. But if you are trying to take the rotor off, you don't need to remove the hub nut.
Old Apr 16, 2004 | 06:46 AM
Highland Runner's Avatar
Yep, you only need to remove the brake caliper to remove the rotor. Very easy.
Old Apr 16, 2004 | 11:35 AM
EDGE's Avatar
Thanks guys, was asking this for a member on another board 4x4parts.com
Old Apr 16, 2004 | 07:00 PM
BruceTS's Avatar
Actually on the newer 3rd generation and a 2000 Tundra that I've worked on all have 35mm nut...
Old Apr 18, 2004 | 03:57 PM
WATRD's Avatar
There's been some extensive argumentation about that on several boards I frequent, including this one. I have always used a 36mm socket on the rigs I have had to pull shafts from and it has worked fine, but some have bought a 35mm and found that it wouldn't fit without grinding. Others have purchased a 35mm and found it fit perfectly.
A year or so ago there was a thread on the TTORA board where 100 or so members chimed in with their findings and the consensus seemed to be that the nut was really something like a 35.5mm. A 36mm works as will a sloppy 35mm socket in some cases.
In looking in the shop manual, Toyota refers to the nut at the "axle lock nut" and lists the torque setting at 174 ft/lbs for it, but of course, they do not specify it's size
Yet another of those Toyota quirks we know and love
Old Apr 18, 2004 | 04:33 PM
Gadget's Avatar
I use a 36mm. It is slightly loose, but in that size it works fine.
Gadget
Old Apr 18, 2004 | 05:13 PM
RTdawgs's Avatar
...torque setting at 174 ft/lbs for it...
no wonder the damn thing is so hard to get off.
Old Apr 18, 2004 | 05:26 PM
BruceTS's Avatar
My 36 mm socket was too sloppy and a 34 mm would just barely fit the end of the nut, I finally had to go out and purchase a 35 mm socket and it fit perfectly. Ironically the nut is kinda of tapered, but I didn't like the sloppiness of the 36 mm, considering the torque requirements.
Jun 1, 2021 01:51 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
CJ94yota
Jul 3, 2015 10:14 PM
