Pro's/Con's of 33/10.5s
Old Apr 25, 2004 | 08:05 PM
  #61
wtmtnterror's Avatar
I could use something
Attached Thumbnails Pro's/Con's of 33/10.5s-04-18-04-007.jpg
Old Apr 25, 2004 | 09:11 PM
  #62
OicnaiC's Avatar
I just trimmed my valance tonight. I left the center part to cover the radiator and cut off the ends, which are usually the part that's banged up the most.
I might make one of these as a replacement tho: http://www.duffcoenterprises.com/ima...05toyfront.jpg
Old Apr 25, 2004 | 09:17 PM
  #63
Scofco's Avatar
Any pics OicnaiC? I need to do something with mine, it looks awful.
Old Apr 27, 2004 | 08:40 AM
  #64
deathrunner's Avatar
I had 12.50's and switched to 10.50's . I did the swap for these reasons:
Lighter, Cheaper, Less drag on the road.
Things I miss:
Wider footrpint in the sand, Wider look on the truck
Overall, I wouldn't switch back. I air down when I hit the sand now, soon I will have long travel which will push my tires out 3 inches (enough to make up for the 1 inch lost in track width. Honestly I think my poor 4 banger is happier not having to face all of that rolling resistance. And with the money I save, I bought a taco. Really money isn't that different.
Old Oct 10, 2004 | 10:14 PM
  #65
saxman285's Avatar
Question Help with a lift
I've been looking through the forums and trying to find as much info as I can, but I have a question. I'm looking to put 33's on my '90 toyota extended cab, sr5, but I don't know how big of a lift to go with. I want it to be high enough so that I don't have any rub, but not too high. I can't really afford a suspension lift for my IFS, so I'm looking at a body lift. Should I go with a 3" lift or just a 2" ?
Any help would be appreciated.
Old Oct 10, 2004 | 10:55 PM
  #66
Brendan's Avatar
you could do what i did - crank the torsion bars up in front a bit and add an extra leaf in the rear. it's cheap, but you do sacrifice ride comfort. i've been considering going back to stock height with 31s lately...
Old Oct 11, 2004 | 10:24 AM
  #67
saxman285's Avatar
well, a body lift really isn't that expensive. It's only just over $100, and the difference between a two inch and a three is only like $10. I just don't know what height I should go with.
Old Oct 11, 2004 | 11:50 AM
  #68
wvuviv30's Avatar
I will say 2" of lift, you can run 33x10.50 on a 89/90-95...
I have BJ Spacers, OME Coils, not rubbing issues with the 33s on stock rims.
more pics and information: http://www.cardomain.com/memberpage/483537/4
Old Oct 11, 2004 | 03:07 PM
  #69
AzStorm's Avatar
Originally Posted by Scofco
I think they look good!
I noticed something in that last photo though. Is there anyone out there who doesn't have a smashed up lower valence? We really need some sort of replacement for that which is a little stronger and doesn't require a new bumper.
Not to highjack the thread,but,try this.
http://www.cardomain.com/memberpage/668548/5
Old Oct 11, 2004 | 04:24 PM
  #70
saxman285's Avatar
would i be better off to get BJ Spacers, and just add a leaf in the back or something? what are the pros and cons... and do they affect the ride or flexibility or anything?
Old Oct 21, 2004 | 04:44 PM
  #71
slyang1012's Avatar
16 x 7 stock rims???
umm.. guys, would i be able to fit 33"X10.5 on stock rims?...i have no money to buy new rims! I believe the stock rims are 16x7! Please tell me it will fit! =(
Old Oct 21, 2004 | 04:58 PM
  #72
dragr1's Avatar
33x10.50x15 will fit on a stock 15x7 rim. As far as I know, no one makes a 33x10.50x16.
Old Oct 21, 2004 | 05:58 PM
  #73
tulsa_97SR5's Avatar
255/85/16 would be close, about 33x10, depending on how close the manufacturer is to the true measurement.
Old Oct 21, 2004 | 06:44 PM
  #74
dragr1's Avatar
True, I think that most 255's are about 0.5" taller than the 33x10.50x15. If I remember it's about 33.3" versus 32.8".
Old Apr 21, 2005 | 11:46 AM
  #75
ToyoRunner94's Avatar
cebby, does that navy blue 4runner have 12.5s or 10.5s?
suppra87
Jul 15, 2021 05:15 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
voiddweller
Oct 2, 2015 07:47 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
Odin
Sep 26, 2015 06:56 PM
