Out of control Horn
Old Jul 1, 2003 | 07:49 AM
kerrs's Avatar
Out of control Horn
My horn keeps going off on its own accord,
The factory alarm system has been replaced with a Clifford Concept 300, but every now & then the horn pulses on and off for about 30 seconds.
any ideas?
Thanks & Regards
Kerr
Old Jul 1, 2003 | 09:29 AM
keisur's Avatar
Re: Out of control Horn
Your horn has it's own Honda?
I would say take it back to the place that installed the alarm, they probably need to adjust something. Or, what happens to my factory one every now and then, the circuit board inside the key transmitter thing gets full of dust and the "arm" button gets jammed down and the thing thinks I'm hitting the panic button and goes off about every 30 seconds until the battery wears down or I take the cover off and give it a good blow with the air compressor, then it works fine again. yes I usually speak in really long continuous sentences,
Old Jul 1, 2003 | 11:55 AM
kerrs's Avatar
Good Joke!!
The alarm has been fitted for over a year now, but the horn thing has only just started. It only does it when the car is really hot (parked in the sun) which is not very often over here!!
Still trying to sort this out as it very annoying
Thanks & Regards
Kerr
Old Jul 1, 2003 | 12:11 PM
asudan96Runner's Avatar
okay so this only happends when the runner is parked?
here is the probem: there is a sensor as part of the alarm that is detecting the change in pressure inside (the air heating up expands) and that sensor is telling the alarm to go off.
Try cracking the windows just a hair and see if that works. I bet that is your problem. If so, take it back and have the sensor replaced or adjusted.
Dan
Old Jul 1, 2003 | 01:13 PM
keisur's Avatar
Dan
AH-HAH, A big giant Thanks DAN!!! I had that same problem when I first got my runner back in '98!! and everytime I took it to the stealer they told me it was the sensitivity and they would just turn the sensitivity down. Well after the third time going in they got tired of seeing me so they turned it completely down to 1 or as far as it would go. I was wondering why I could arm the alarm and then wash the car and it would never go off! I am going to go outside my office right now and turn that sensor back up, I guess I can count my blessings no-body has made off with anything, except the runner because I know the ignition cut-off would have still prevented it from being started. thanks again,
Old Jul 6, 2003 | 10:14 AM
kerrs's Avatar
Thanks for that, I'll give it a try.
Regards
Kerr
Old Jul 6, 2003 | 12:27 PM
Citykid's Avatar
How can we adjust the sensitivity of our stock alarms?
Old Jul 6, 2003 | 06:12 PM
keisur's Avatar
Underneath the Steering column is a black box. on it is a little dial with a slot in it, the dial is graduated with 7 marks {I think} the higher the number the higher the sensitivity. just stick your head and a flashlight under there and find it, then take a small screwdriver and turn the dial, the stealership chumps turned mine all the way down to 1 or lower and I just turned it back up to around 3-4 and I'll give that a shot for a few weeks.
kawazx636
Oct 6, 2021 03:03 PM
aowRS
Sep 13, 2017 08:22 AM
kcaudill
Oct 10, 2015 02:39 PM
toyotasaurus
Sep 24, 2015 03:30 PM
JRB4Runner2015
Sep 20, 2015 12:29 AM
