OME Front Suspension Install Help
Old Oct 31, 2004 | 05:40 PM
hunter16's Avatar
Attempting to install an OME suspension in my 98 4Runner but having tremendous trouble compressing the front coil spring with coil spring compression tools and still having room to fit the spring/shock while compressed. Any help regarding compressing the spring/installing spring/shock in front?
Old Oct 31, 2004 | 05:49 PM
fourunnabilly's Avatar
Guest
Keep compressing...you may want to disconnect the ball joint that links the top of the spindle to the upper control arm and jack that part of the setup down to get more clearance. other than that(sorry, 4th gen cat here), just get tough with the sucker and send it into place. hope that helps.
anthony
Old Oct 31, 2004 | 05:56 PM
waskillywabbit's Avatar
Talking
I got a front OME write-up on my website but my website is acting up at the moment, so check it tomorrow.
Old Nov 2, 2004 | 04:44 AM
calg3's Avatar
Yes, this has been covered before. Some people have had success using the OEM bottle jack to help get the assembled spring/shock assembly in place.
Old Nov 2, 2004 | 04:49 AM
Talking
Perhaps this might give you some insight...
http://www.drawhorn.org/front_ome_install_writeup.htm
So turn the damn lower cup the other way...
Old Nov 2, 2004 | 05:23 AM
sschaefer3's Avatar
Originally Posted by waskillywabbit
Perhaps this might give you some insight on how to install the parts the wrong way...
That's a great write up on how to incorrectly install the lower cup.
Old Nov 2, 2004 | 05:25 AM
sschaefer3's Avatar
and when you install the cup the wrong way you don't get the 1.5" of lift the coil provides.
Old Nov 2, 2004 | 05:35 AM
Talking
I can always count on you for encouragement Steve!
This pic might prove helpful...
Old Nov 2, 2004 | 05:59 AM
sschaefer3's Avatar
I can always count on you for those late night spooning sessions, when's our engagement Steve!
Let your freak flag fly baby!
Old Nov 2, 2004 | 06:17 AM
uboatcmndr's Avatar
Can't you two see that you're in love! have a good day, mike
Old Nov 2, 2004 | 07:48 AM
MTL_4runner's Avatar
Old Nov 2, 2004 | 08:01 AM
BajaRunner's Avatar
Do you have the coil-shock assembled? Is it all ready to be installed in to the truck?
If so, the best method is used above. Take your bottle jack and put it upsidown on the upper a-arm and the inside wheel well. Screw it till it is pushing down the A-arm at a pretty good angle. Make sure that its secure though, because I had it pop out on me!
Best thing to do is put it far down so you can install the newly assembled strut...hand tighten the top three bolts, and then ajust the jack up/down until you can look through the bottom eyelet mount and stick that big bolt back through.
You know that you have to take the coil spring compressors off before installing, right?
Old Nov 2, 2004 | 08:22 AM
terryjmatthew's Avatar
I think SC4Runner just hit the nail on the head! LOL...
Old Nov 2, 2004 | 09:30 AM
BajaRunner's Avatar
Thats a first... my thumb is usually the thing I hit...
Old Jun 22, 2006 | 08:44 PM
DuraAce's Avatar
Wink Strut mount replacement?
Is the strut mount usually repaced or can the old ones with (133K) be reused.
Thanks
Dura Ace
Old Jun 23, 2006 | 04:30 AM
Thanks
Dura Ace
You can reuse them just fine about 99% of the time.
Old Mar 26, 2007 | 07:26 PM
Fo-runna's Avatar
I saw the rear install but not the front. Am I blind?
Sep 4, 2015 09:27 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
deepmarsh
Aug 6, 2015 03:44 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
Vargntucson
Jul 4, 2015 12:15 PM
