oil sending unit
Old Jun 8, 2003 | 01:35 AM
byondevl's Avatar
oil sending unit
I changed my oil and noticed a small white plastic clip that should have a wire connect to it....broken as if someone tried to remove it with pliers?
Any how, i belive this part is the oil pressure sending unit.
so at the moment my tacoma is operating without this device.
Will this harm my truck?
Old Jun 8, 2003 | 06:03 AM
Todd E's Avatar
It won't hurt to run without it, but if something should happen (like a rock gouging a hole in your oil pan), you won't have any warning of oil pressure loss.
Should be easy enough to find the cut wire and splice it back up.
Just one of those safety things :-)
Todd
Old Jun 8, 2003 | 04:05 PM
byondevl's Avatar
the problem is that there is a plastic plug lookin thing the wire goes into...it has been destroyed by something or someone.
Old Jun 8, 2003 | 05:16 PM
Todd E's Avatar
OK, I got it now
You should be able to pick up the connector either at the dealor or a place like radio shack (don't know if you have those over there) and wire it in.
I don't know what kind of connector it is, but most likely it's a "spade" type.
Good luck!
Todd
Doug4320
Mar 24, 2018 10:11 PM
gary4runner
Sep 24, 2015 12:53 AM
skoti89
Sep 11, 2015 07:46 AM
Odin
Jul 15, 2015 09:28 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
