New Exhaust
Old Apr 4, 2004 | 03:11 PM
nigeltufnel3's Avatar
Arrow New Exhaust
I am looking to put a new exhaust in my 1994 Pickup (4x4, 22RE). My muffler is cracked and i think the cat. is plugged up. I figure while I'm at it I might as well increase performance, so I want a whole new setup, and possibly a header too. I'm on a budget so I just want something practical. My question is if I replace the muffler, cat., and pipes with the same size ones will I have to weld anything or can I do it myself? Also, how do i get the o2 sensors into the system? Thanks for all the help, I really don't know too much about this stuff. Any help, advice, reccomendations, etc. are greatly appreciated.
Old Apr 4, 2004 | 06:52 PM
ElwayLite's Avatar
Id go to a local shop, pick a good muffler like a dynomax or flowmaster and let them run new piping for you with teh muffler and a new cat, be the cheapest way. Then throw down on some headers later.
Old Apr 4, 2004 | 07:55 PM
notaco's Avatar
just cut it off behind the cat and call it good
Old Apr 5, 2004 | 07:29 AM
X-AWDriver's Avatar
RICER!!!
Old Apr 5, 2004 | 11:39 AM
Fink's Avatar
I'd call that a more redneck thing to do...unless they run straight pipe and weld on a used coffee can to the back and its done on an '87 Paseo or Tercel.
Fink
Old Apr 5, 2004 | 03:13 PM
notaco's Avatar
actually it was a trail repair that never got fixed
Old Apr 5, 2004 | 05:56 PM
Thanks for the help. Do you suggest I get the muffler and cat. beforehand. I can get the muffler (dynomax superturbo) for about $20 and a catco cat for about $30? Also, I think the stock pipe size is 2", but can I put on a 2.25"??Thanks again for all the help.
Old Apr 5, 2004 | 07:52 PM
ElwayLite's Avatar
Yeah, if you can get the stuff beforehand for cheaper and just let the shop install the pipe and stuff for you. 2.25" is the max to go on a 4 banger without losing too much backpressure.
Old Apr 6, 2004 | 10:49 AM
thanks for all the help......just one last question......would you reccomend 2.25" or stick with 2"????? Thanks again, i appreciate it.....
Old Apr 6, 2004 | 10:52 AM
DavidA's Avatar
Where are you getting the muffler and cat from so cheap? Those are pretty good prices!
Old Apr 6, 2004 | 01:18 PM
ElwayLite's Avatar
I'd personally go 2.25.
Old Apr 8, 2004 | 01:19 PM
well, i called a couple shops and they want like over $200 to install the cat and muffler......can i do it my self, or do i need to weld it up at all.......if i got a new pipe and a 2"->2.25" fitting, could I do it all??? thanks for the help......
Old Apr 8, 2004 | 02:32 PM
ElwayLite's Avatar
Well, doing it yourself would be a pain and some welding would be involved. Shop around, $200 is a little steep, also, if your stock piping is ok you could just have them put the cat and muffler in place of the old an dkeep the stock tubing to cut cost.
Old Apr 8, 2004 | 05:45 PM
Fink's Avatar
$200 is definately too much...it only cost me about $25 as a base price (minus tax, the tailpipe and some other stuff I had done) to get just my muffler put on. It doesn't require anything special to put a cat on as well...just more cutting and welding. I would look for maybe around $60-$100 at the most for the whole thing.
Fink
Steven.m.paulk
Jun 7, 2020 10:45 AM
the_supernerd
Oct 1, 2015 09:20 PM
voiddweller
Sep 28, 2015 11:21 PM
Keithstoyota
Sep 27, 2015 07:29 AM
