New 22re,not starting
Old Aug 20, 2005 | 06:14 PM
JEDI87's Avatar
I just got my rebuilt 22re in and it won't start.It will fire but wont run.I have to have some exhaust work done to accomidate the new header so right now it's just header,it ends under the pedals.It pops and backfires.The firing order is good.It ran when I pulled it into the garage and I have a feeling I am forgetting something.Any ideas?
Old Aug 20, 2005 | 06:16 PM
Rivalred's Avatar
Are you getting fuel?
Old Aug 20, 2005 | 06:27 PM
JEDI87's Avatar
I just pulled the fuel line off of the regulator and cranked the engine and nothing came out.
Old Aug 20, 2005 | 06:41 PM
JEDI87's Avatar
I just tested the pump and it is good.I don't smell gas in the cylinder though.
Old Aug 20, 2005 | 06:53 PM
Rivalred's Avatar
Well, your not getting fuel into the cylinders then.
94x4's Avatar
Guest
Keep searching, keep serarching, you'll find it..., eventually.
There is gas in the tank, right?
Old Aug 20, 2005 | 07:21 PM
JEDI87's Avatar
There had better be!It's wierd,It pops and backfires like the timing is off or the firing order is off but I have quadrupal checked everything.
Old Aug 20, 2005 | 08:06 PM
87TurboYota's Avatar
Thats strange another car I have is doing the exact same thing I don't know what's wrong either.
Old Aug 20, 2005 | 10:43 PM
JEDI87's Avatar
I need to see if the injectors are firing.I am smelling some gas now but still no fire.I have good spark,rotor faces #1 on the dist on the compression stroke,I'm stumped .Would it matter if for some reason the machinest put in a cam for a 22r not a 22re?I doubt that's what happened but I am thinking of every possibility.
Old Aug 21, 2005 | 01:07 AM
jimbo74's Avatar
pops and backfires is vacumn leaks or 180* off on the timing.... make sure it is set properly.... when i was rebuilding my 22r, i did this... my friend who is a mechanic was liek dude, it wont start because i can tell by that sound your distributor is 180 off
Old Aug 21, 2005 | 02:13 AM
JEDI87's Avatar
I put my finger over the spark plug hole on the #1 cylinder until I felt the air push out.That put the timing mark on the 0* on the timing tab.That is where I put the distributor in with the rotor pointing to the #1 terminal on the dist cap.
Wait,wouldn't that put it 180* out?
Old Aug 21, 2005 | 06:57 AM
4Crawler's Avatar
Sounds like an air leak between the air flow meter and the throttle body. When I have had leaks it would do the same. And you can rule out the fuel pump with the FP test jumper:
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Aug 21, 2005 | 07:08 AM
javadoody's Avatar
ya, you could be on the exhaust stroke, not compression. pop the cover and watch the valves.
Old Aug 21, 2005 | 11:10 AM
JEDI87's Avatar
Well I just reinstalled th dist and it is still doing it.I don't get it.It's getting gas,spark but no start.
Old Aug 21, 2005 | 01:34 PM
trx125's Avatar
Crossed Plug wire? fo 1423 ( I think) where most 4 bangers r 1432 I checjk brb!
Old Aug 21, 2005 | 02:03 PM
JEDI87's Avatar
The firing order was set 1234.All are right now.
Old Aug 21, 2005 | 02:07 PM
Yamaha+Toyota=Fun's Avatar
Have you checked for codes?
Old Aug 21, 2005 | 02:18 PM
JEDI87's Avatar
Woo Hooooo!!!! It's running now and has major throttle response and torque,Thanks guys.
Old Aug 22, 2005 | 08:19 AM
ToyotaGuru's Avatar
Firing Order
The correct firing order is 1432 Clock wise. Number one is at 11 o'clock.
Cams won't matter the backfire sounds like the wires are crossed. FYI the
EFi motors are set with the crank set a 5 BDC. Check to make sure the Knock Sensor is plugged in (Passenger side of block to right of the fuel filter.
Old Aug 22, 2005 | 10:58 AM
pinemind's Avatar
I'm probably posting what's on everyone's mind after all these suggested solutions:
What was the problem/fix that got it running? Or was it just a fluke and it just started up one time?
Justin
