my power windows
Old May 13, 2004 | 12:27 PM
WIZARDOFODDZ's Avatar
my power windows
won't work. I tryed everything. My back window works most of the time, but the passanger and the driver side window won't work, Any ideas?
Old May 13, 2004 | 02:07 PM
doink's Avatar
perhaps a bit more info as far as what type of vehicle you have will speed up the number of replies.
Old May 13, 2004 | 03:00 PM
Sorry, it's a 1987 4 runner
I have tested all circuits with a test light, NO power.
I have 214000 miles on my baby and I don't want this to be the end. Is there a relay of some sort, if so where?
Old May 13, 2004 | 04:26 PM
Nam's Avatar
Nam
Get a circuit diagram and start tracing it. Let me know if you do not have access to the electrical diagram of your vehicle, I will try to pull it out from my repair manual.
Good luck,
Nam
Old May 13, 2004 | 04:45 PM
Nam
I have already searched the wiring diagram. It shows a power window relay, but it's not there. I live in upstate New York, not someplace you want your windows stuck.....LOL Up or down.
It shows a relay next to the manual brake handle, nothing there????
I also called a couple of dealers im my area, no one seems to know. My next post may be in the classified area :con
Old May 14, 2004 | 02:26 PM
no help???????
come on
Old May 14, 2004 | 07:57 PM
Mossback74's Avatar
Are you getting any power to the switches?
Old May 15, 2004 | 04:06 AM
Mossback74
No, I have no power to the switches. That is why I was thinking relay. I called another dealer on friday, they said they have a part listing for a power window relay ($294) but had no idea of the location. Looks like I have to do it the hard way, take EVERYTHING apart and start tracing wires
This is going to suck, I can't believe the cost and who knows where and when it I'll get it.
Old May 15, 2004 | 10:39 AM
power windows
Does anyone know where the window relay is located in a 1987 4 runner?
Old May 15, 2004 | 02:34 PM
bump it up
Old Aug 18, 2005 | 12:24 PM
4Hummer's Avatar
Free Bump having the same problem with my brother in laws truck
Old Aug 18, 2005 | 02:43 PM
Flamedx4's Avatar
It's D6 - see if this helps.
The objects next to it are A12 Antenna relay and O10 Overdrive relay.
Assuming you started with the fuse?
Assuming it is indeed a bad control relay - if you cannot find a cheaper source for a replacement, if you wanted to you can wire around it quite easily, or put in a $4 simple relay. All the "control" relay does for all that money is give you the time delay after the ignition is turned off. It simply feeds power on/off to the window switches, but has a 60 second "off" delay. Nice feature but not worth $300 to me!
Old Aug 18, 2005 | 02:57 PM
Flamedx4's Avatar
I edited down the relay diagram (@#$& 49k picture size limit) for ya.
Good luck.
Old Aug 18, 2005 | 03:06 PM
Flamedx4's Avatar
This one is clearer
Old Aug 19, 2005 | 08:42 AM
4Hummer's Avatar
Seems on the later 1st gen Runners they use a Power Window Module not a relay, Toyota wanted $419 Cdn plus 15% Tax for this puppy. (Stupid Stealerships)
FIX:
Run a power line from the battery with a 30AMP fuse, into the door. Splice this Power line into the Blue Wire with Red Stripe (Located: Drivers Side Window Switches)
This Bypasses the Power Window Module all together. The neat part is that the windows will go up and down with out the key in the ignition.
Jun 1, 2021 01:51 PM
westonian18
May 1, 2020 06:38 AM
okamikai
Apr 30, 2018 10:19 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
Johntom240
7
Jul 13, 2015 12:18 AM
