My Bad Yukon Gears
Old Mar 11, 2005 | 08:02 AM
  #61
dragr1's Avatar
Originally Posted by ZUK
Ya....in the pic you can even see that there appears to be no thread. haha...this is a funny bolt diagram from the 4x4wire site I think the very last style of bolt would have worked for the Richmond stuff!
hehe
That tapered bolt might have worked good for me. The Toyota bolts could grab about the bottom 1/2 of the threads but the top half of the threads were useless! The bolts would wobble around in the threads like a childs toy-remember the Weeble Wobble!
Old Mar 11, 2005 | 08:38 AM
  #62
bamachem's Avatar
well, i hope i have better luck. after doing my homework, i still ordered yukons.
4.56 front and rear w/ front and rear master install kits. i have 126k on my bearings, i figured i might as well replace them while they're all pulled...
got them for $501 shipped to my door for everything...
Old Mar 11, 2005 | 09:56 AM
  #63
dragr1's Avatar
Good price, post pics of the gears when you get them. See if they have a part # TV8488 (I think) on them or do they say "Sprtsman".
Old Mar 11, 2005 | 10:03 AM
  #64
bamachem's Avatar
will most definitely do that.
i'll have them next tuesday or wednesday.
Old Mar 12, 2005 | 08:57 AM
  #65
Firetaco's Avatar
where did you find that and do they offer a 4.88 good price dude!! later
Ernie
Old Mar 12, 2005 | 03:42 PM
  #66
bamachem's Avatar
Ernie
member name "porc" on pirate.
alex at performance offroad in athens, ga.
yup. 4.88's or anything else you'd want including arb's...
Old Mar 20, 2005 | 01:41 PM
  #67
dragr1's Avatar
Latest update, I've got 250 miles on it now. No problems so far, it drives great. Starting from a stop is so much easier now, so far is one of the best mods I've done, maybe only second to the locker.
I checked the speedo with my gps today and it looks like it's about 14% off, up from the 11% it was off with the 4.30's. I did hit the trip odo when the gears were installed, but I forgot to hit the other trip odo when I filled up with gas. So, I went ahead and refilled with gas today and I'll track it from here. If I remember correctly I filled up with 40 miles and refilled today with 232 miles. That's 192 miles and corrected should be 218.88 miles and pumped in 11.006 gallons and that equals 19.88 mpg, which seems unbelievably high b/c I was getting about 14-15 mpg in town and almost all these miles were in town. I think I must of had more than 40 miles on the trip before I refilled, so I will post again when I fill up again.
Old Mar 21, 2005 | 03:36 PM
  #68
bamachem's Avatar
look what the ups man brought me today...
I got lucky with my Yukon experience - they're US made Richmonds, and yes, I've already checked the ring gear bolt holes...
Old Mar 21, 2005 | 04:10 PM
  #69
dragr1's Avatar
Yep, exactly what I had the first time, except for the ring gear bolt holes. Keep us posted on the install.
Old Mar 21, 2005 | 04:53 PM
  #70
sschaefer3's Avatar
Did yours say USA?
Old Mar 22, 2005 | 06:52 AM
  #71
bamachem's Avatar
they're all made in the USA - South Carolina to be exact. Forged from US Steel and Heat Treated in the same facility as the high-end Richmonds.
http://www.richmondgear.com/sportsman/SportsmanCat.pdf
Old Mar 22, 2005 | 07:19 AM
  #72
SteveO's Avatar
so i guess my setup has been a good one, I have had no problems with the Yukons......4.88
Old Mar 22, 2005 | 05:21 PM
  #73
dragr1's Avatar
That's good to hear, how many miles are on yours?
Old Mar 22, 2005 | 05:35 PM
  #74
SteveO's Avatar
I suppose around 5k, with maybe 500 hard miles, trail miles. I don't drive my rig that much, most of the time it sits on the side of the house. One thing I was sure to do was break them in correctly. I had ORS put in the gears in Colorado. It was a long, long drive back to Santa Fe, NM.
Old Mar 22, 2005 | 05:40 PM
  #75
dragr1's Avatar
I'm going through the break-in right now and I'm following everything meticulously. I don't want any problems down the road. I don't drive mine much either-maybe 8k miles a year-in fact I'm letting the wife drive it to work just so I will get the break in miles on there before going to Tellico in May.
Old Mar 22, 2005 | 06:09 PM
  #76
sschaefer3's Avatar
I have 45K on the rear Yukon 5.29's. Installed in March of 2002.
I do want to pull the rear 3rd and have a look at it, just for the heck of it.
Front Dana 44 Yukons are still new. 20-30 miles on those guys.
Old Mar 22, 2005 | 08:00 PM
  #77
sgirt's Avatar
What is your RPM with the 4:88's at 65. With my 4:88's V6 2000 5 sp 4runner I was 3200 rpm with the speedo showing 65. I have 285's and in5th gear. I am not sure what my actual speed was. This is too high IMOP.
My Yukon 4:88's are stamped Richmond. The setups have been horrible. I had them setup twice buying the installation kit twice. Both times the pinion became loose after about 100 miles. I ended up pulling the 4:88's and installed 4:30's from a wrecked 4Runner. Can't keep spending $250 a crack to have someone setup the rear end. Anyway, my RPM's are much better with the 4:30's.
** BTW, I am selling my New 4:88's front and E-locking 4:88 rear. Only 2 months old! Rear needs setup again.**
Old Mar 22, 2005 | 08:23 PM
  #78
sschaefer3's Avatar
If the pinion is walking, they were not set up right. That is a common one.
4.88's and a 3.4 V6 need 315/75/16 to match the stock 265/70/16
4.56 and a 3.4 V6 need 285/75/16 to match the stock 265/70/16
5.29 and a 2.7 Liter 4Banger needs 315/75/16 to match the stock 265/70/16
2.7's with the 265/70/16 come new with 4.56 gears.
Finding a qualified gear installer is not easy.
Old Mar 22, 2005 | 08:34 PM
  #79
sgirt's Avatar
Yep pinion is all over. I don't think they crushed the crush sleeve at all. I have the one from the first install. It looks just as tall as the one that they put in the second round.
I wanted 4:56's and mathmatically 4:30's will work going from a 31 to a 33. I still would prefer to have 4:56's but they are hard to find. I am done paying someone to setup at my expense the ring and pinion. I have over $1200 in the rear 3rd in parts and labor and it is sitting on my work bench. For that I could have bought a new one.
Old Mar 22, 2005 | 08:35 PM
  #80
dragr1's Avatar
Checked it by GPS, 60 mph indicated, was 68.5 mph on the GPS. I think it was around 3000 rpm with 285's. It wasn't over that though. I calculated that I would run 3400 rpm at 80 mph, versus 3150 at 80 mph for the stocker with 28.4" tires and 3.90 gears. Since I don't run 80 very often, I like the extra rpm's, it helps haul the extra weight of all the add-ons and the mass of the larger tires. I would bet that the 285's add 25 pounds of rotating mass at each wheel over the stock tires. Rotating mass will have a greater effect per pound on your performance versus overall weight.
