Old Mar 30, 2016, 03:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Towing & Hauling Guides
Print Wikipost
mods to increase towing power for a tacoma...please help!
Old Nov 3, 2003 | 05:50 PM
wimpywade94's Avatar
i need to know some mods that will help increase power when im towing, its a 98 tacoma with 32's and some lift. i need to be able to tow at least 5000 pounds without problems, i have done the deckplate and i have done my version of the isr mod, what next? i may do the ect mod next, dont know if i want to mess with that or not though! im thinking, new cat back exhuast? how much will that help? thanks a bunch
wade
Old Nov 3, 2003 | 06:22 PM
Jonathan's Avatar
regear, throw a SC on their and forget about it
Old Nov 4, 2003 | 06:34 AM
ewarnerusa's Avatar
trade it in for a 3/4 ton
Old Nov 7, 2003 | 07:47 AM
Duffdog's Avatar
I regularly tow 9000 lbs with my sc tacoma-- not by choice mind you. towing a heavy load sucks with a supercharger because you have to use the low end torque and the engine doesn't like it and starts pinging after a few seconds--there is no way to stop this, I have all the fuel mods--headers, intake, exhaust, injectors, safc and anything else and it still pings when towing. it doesnt ping when driving around normally. if i had a choice, id get a tundra for towing. small engines cant tow anything-- i dont care what anyone says--unless its like 2000lbs, which is nothing. for doing real work, get a v-8
T
Old Nov 7, 2003 | 07:49 AM
ewarnerusa's Avatar
Originally posted by Duffdog
I...small engines cant tow anything-- i dont care what anyone says--unless its like 2000lbs, which is nothing. for doing real work, get a v-8
T
100% agreement. Get a 7.3L Power Stroke turbo diesel V8 like our work truck...
Old Nov 7, 2003 | 07:56 AM
KING's Avatar
....Or a 6.0L POWER STROKE TURBO DIESEL with 560 FT. LBS of TORQUE @ 2000RPM!
Old Nov 7, 2003 | 08:08 AM
ewarnerusa's Avatar
Originally posted by KING
....Or a 6.0L POWER STROKE TURBO DIESEL with 615 FT. LBS of TORQUE @ 2200RPM!
I saw a new F-250 with 6.0L diesel. Is that new and smaller than our 7.3L? or is the 7.3L a bigger model still? All I know is that thing could tow the space shuttle if we needed it to. and the diesel growl is great, it frightens other motorists.
ahhhh.....here's my answer. "A new 6.0-liter Power Stroke diesel engine is available for 2003 models that’s cleaner, more efficient, and more powerful than the outgoing 7.3-liter diesel. Though smaller in displacement, the new 6.0-liter turbo-diesel V8 is rated 550 lbs.-ft. of torque at 2000 rpm. The outgoing 7.3-liter Power Stroke turbo-diesel, available on early 2003 models, offered up to 525 lbs.-ft. at just 1600 rpm. The 6.0-liter engine produces 325 hp at 3300 rpm, compared with the 7.3-liter’s max 275 hp at 2800. "
Old Nov 7, 2003 | 08:46 AM
Toddski's Avatar
Wade...
I hope you don't plan on towing for a distance. You will kill the Taco.
The Tacoma is only rated to tow 5,000 lbs. But you need to look at the specs.
That 5,000 lb capacity is with a bone stock Tacoma with one 150 lb person, 1/2 tank of gas, no radio, no air no nothing.
When you add stuff to the Tacoma like gas ( 1 gallon of gas = 5.8 to 6.5 lbs) radio, and air you need to subtract these numbers from the 5,000 lb tow rating. Next thing you know, you have added 500 lbs of weight and reduced your towing capacity to 4,500 lbs.
I own a '97 GMC Yukon with a 5.7 liter V8 that weighs around 6,000 lbs. It has a towing capacity of 6,500 lbs.
I tow a 23', 5,000+ lb trailer. I have trouble in the mountain passes with the big V8 and sometimes in strong head winds it slows me down a bit.
Look at what my trailer does to the rear of my Yukon with only a 300 lb tongue
This is the reason i sold my '97 4runner and purchased the GMC.
If you are planning to tow often then i highly recomend going to a RV forum and read over some of the posts there. So often people purchase a travel trailer thinking there mimivan or small pickup will tow 5,000 lbs because that is what the manufacturer said.
You can tow that much if you are on a flat ground going short distance, but if you plan on adventuring farther then you might want to look at a different set up.
If you want any other info let me know. Just don't want to see you burn up your rig because of some bad advertisement.
Later.
vanion2
Jul 29, 2015 06:17 PM
1996Taco
Jul 20, 2015 12:02 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Massmayhem247
Jul 18, 2015 05:46 AM
cars-guy
Jul 11, 2015 07:51 PM
