Lockers
Old Mar 26, 2003 | 12:34 PM
Brian Baker's Avatar
Lockers
I have been looking into lockers, and would like to get some input on what others are using. I have a 2nd gen 4-runner.(1993) I have been considering the Detriot EZ-Locker, but am open to input. Thanks in advance. Brian
Old Mar 26, 2003 | 01:55 PM
Cebby's Avatar
Check this thread. Lots of good info.
Locker thread
Old Mar 26, 2003 | 07:40 PM
upndair's Avatar
The Lock-Rite is a pretty good inexpensive alternative. It's fairly easy to install but it's not a great choice if your running 35" or larger tires, or a big motor.
I had to toss mine trying to run them with 37" tires.
Old Mar 27, 2003 | 01:01 AM
PoBoy's Avatar
I have the Detroit EZ Locker...I am quite satisfied with it. Great bang for the buck...but it does BANG. Its a full time locker, so when you turn, your tires will sqeal or it will make a clicking noise. I kinda like it, people always stare like somethings wrong with my 4Runner. Anyway, Ill be putting one in the front too...DETROIT 313 represent...LOL
Old Mar 27, 2003 | 09:36 AM
decepticon's Avatar
will a lock rite do the same as you described above?
Old Mar 27, 2003 | 10:36 AM
PoBoy,
Can you please explain "Detroit 313". I'm just starting to do my research and am not familar with this yet. Thanks Brian
Old Mar 27, 2003 | 10:52 AM
PoBoy's Avatar
Originally posted by Brian Baker
PoBoy,
Lol...Its an area code in Detroit. If you dont live in REAL Detroit or atleast a few blocks from it, you wont have the 313 area code. You'll have 810, 245, ect. Thus in the movie "8mile", everyone was chanting 313, because they lived in real Detroit and south of 8Mile. Its a respect thing...My ass lives off 6mile
I dont know anything about the lockright, but if its a full-time locker...it will do the same. When I had my old BFG MTs, they chirpped when I turned. But with my goodyear MTRs, they grip so well that the locker bangs
Old Mar 27, 2003 | 06:48 PM
Marc P's Avatar
I recently installed a Detroit Soft Locker. It is a newer design, and I love it. On the road I can feel it once in a while, but it makes no noise.
Off road it is impressive. Hills that I would have had trouble going up are a cake walk.
It replaces the stock carrier so it is the strongest alternative. My buddy who is a Ford mechanic installed it in just a couple hours. I also replaced all the bearings at the same time.
Old Mar 28, 2003 | 12:05 AM
PoBoy's Avatar
Marc, what does yours do when you turn? How does it compensate for one wheel needing to turn more than the other?
Old Mar 28, 2003 | 04:49 AM
Marc P's Avatar
Poboy,
turns are a little tricky. If you let off on the gas and coast around the turn the detroit will unlock and let the inside tire spin freely. If you stay on the gas--especially in a merge situation the inside tire will chirp every time.
I am pretty good about not chirping it. I just stay on the gas lightly and it works fine.
Old Mar 28, 2003 | 06:04 AM
upndair's Avatar
Yes it will.
Old Mar 28, 2003 | 07:15 AM
Marc P,
Did you do front and rear? What did it cost you? Any info you could share would be great.(Part numbers, extra cost, etc.) Thanks for any help you can provide. Brian
Old Mar 28, 2003 | 07:31 AM
upndair's Avatar
I wouldn't recommend a full time locker in the front. I'd go with a selectable locker. ie electric or ARB.
You lose a lot of steering control with a full locker. When I turn on my ARB it's tough to even turn the wheels!
Old Mar 28, 2003 | 09:05 PM
Marc P's Avatar
I only did the rear. I still have the auto locking front hubs, and lockers, unless selectable do not work.
I bought the locker for $405.00 Master install kit $125.00 and my buddy installed it for $100.00
By far the best mod I could do for my runner
Old Apr 9, 2003 | 07:46 AM
ravencr's Avatar
Has anyone installed a Lockright in the front axle of a 1998 or one with the same axle? If so, how does it drive when in 4wd and 2wd? How's the steering effected when in 4wd and 2wd? Any problems? Is the install as easy as the rear sounds like it is?
Chris
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
