light help
Old Jan 19, 2005 | 02:50 PM
jimbo74's Avatar
light help
my aux lights are wired on their own circuit with a fuse and relay... anywyas... i want to make them also lighted by my highbeam switch... what wire do i tap and i jsut connect that into my other signal wire to the relay right?
Old Jan 19, 2005 | 02:59 PM
shotking4's Avatar
for my old driving lights, i didn't use a switch. I bypassed the switch by just wiring that lead from the relay right into the high beam light wire right behind the bulb. I think you can run a wire for power from the switch to the same wire. That is how my fogs are set up but they are tapped into the low beam wire under the steering column inside the dash. I think the red and green wire down there on my 98 runner is for high beam power but i'm not sure. Worst comes to worst i will just run a wire from the switch back thru the firewall and up to the wiring harness at the bulb and tap into it there. Hope this helped
Old Jan 19, 2005 | 05:11 PM
jimbo74's Avatar
is the highbeam wire color on my truck the red/green?
i have 3 colors: red/green, red/black, red/yellow
Old Jan 19, 2005 | 06:05 PM
jimbo74's Avatar
i already have it all wired up except for the t splice onto the headlight... come on, someone knows
im also setting up my turnsignal to alternate flash with tha parking light
Old Jan 19, 2005 | 06:37 PM
dibble9012's Avatar
Hey ill go check on my truck, what year is yours? Mines 2000, don't know how much of a difference there would be though, I use H4 bulbs.
Old Jan 19, 2005 | 06:46 PM
jimbo74's Avatar
i also have h4 bubls.. my trucks an 1985 pickup...
Old Jan 19, 2005 | 07:07 PM
shotking4's Avatar
i would guess that the red black is the ground. you can always pull the the plug out of the bulb. Put your high beams on and then stick the wire from your driving light wiring harness and see which one lights up your driving lights. I did this the first time i wired lights on my old van. I'm also assuming, and i know why i shouldn't assume, but i'm goin to do it, the wire will be the same color behind the bulb and under the dash. give me a minute and i'll check and see in my runner
Old Jan 19, 2005 | 07:15 PM
kyle_22r's Avatar
i'd say pull the cover off the steering column and break out the wire tester. toyotas aren't usually too hard to figure out, unless you look at the wiring diagram :eek:
Old Jan 19, 2005 | 07:17 PM
jimbo74's Avatar
i pulled off the bulb socket, and 2 of the terminal have power
Old Jan 19, 2005 | 07:23 PM
shotking4's Avatar
what colors are the two wires that are giving you power? this may be a dumb question but do your low beams stay on with your highs? Let me know what color the two wires are
Old Jan 19, 2005 | 09:36 PM
jimbo74's Avatar
there are 3 wires... one is ground... cant tell what the otehr 2 do, toyotas used a backwards ground system or something....
Old Jan 19, 2005 | 10:06 PM
jimbo74's Avatar
well i jsut sent an email to roger brown... he responded.. said it was most likely red/green... and since anotehr member here said that also... i tried it.. it worked..... now i get my brights to come on and my aux lights... and my aux lights are still wired to come on manually eiht an in cab switch
Old Jan 19, 2005 | 11:11 PM
jimbo74's Avatar
here is the way my ligths are set up... they run with either the switch in the cab, or whenever the highbeams are turned on
ashersullivan88yota
Jan 18, 2022 05:37 PM
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
