LED and resistor Q's
Old Feb 4, 2004 | 06:02 PM
sick4runner's Avatar
Ok guys, whip out your Physics books,
I just ordered some LED's off Ebay and would like to wire them into the foot wells in groups of three to light them up when the doors are open, later on I will move to the Dash and switches etc. But for now I just have simple wiring Questions to throw at ya.
Here are the specs:
10mm Red LED's
2.2v
30mA
If I wire them into groups of three should i wire them in parallel with one resistor, or series with one resistor. Or should I put individual resistors on each of them. AND what rating (ohm's) should the resistors be??
Old Feb 4, 2004 | 06:21 PM
arjan's Avatar
I would use a resistor for each LED. (Resistors are cheap).
To calculate the resistor:
Voltage accross the resistor: 12V - 2.2V=9.8V
Voltage=Current * Resitance therefore the resistance equals the Voltage divided by the Current: 9.8/.03=326 Ohms. The closest value will be 330 Ohms.
The wattage for the resistor has to be at least 9.8V * .03A = 0.294 Watts. I would use 1/2 watt resistors.
Anyway a 330 Ohm, 1/2 watt resistor per diode will do the trick.
Arjan
Old Feb 4, 2004 | 06:25 PM
Unhappy99's Avatar
Series wired, one resistor.
Leds should be driven at 20mA, not 30mA, unless you want them to die early.
V=IR
Normal car battery voltage is about 13.8, so:
(13.8 - 2.2 -2.2 -2.2 ) / .02 = 360 ohms
Power = I^2 * R, so the minimum power rating of the resistor should be:
.02*.02 *360 = 0.144 watts.
Old Feb 4, 2004 | 06:41 PM
thanks guys, quick response.
I think i will run them at 30 because they were advertised as ultrabright, long lasting, which i think means that they can withstand a little more current. but I'll see when they burn out right:pat:
Old Feb 4, 2004 | 06:56 PM
arjan's Avatar
In my calculation I took the resistor value above the calculated value. If you take 13.8 volts at 330 Ohms you'll run at 41mA. So you might want to go one step up to 390 Ohms. I don't think there is any values in between those numbers unless you get into higher end resistors. Normal resistors are manufactured at 10% accuracy so a 330ohm could be as high as 363Ohms and a 390Ohm could be as low as 351Ohms. That's what they told me at school anyway. For that reason they don't make the values in between unless you take 5% resistors and I think they have an extra colour band.
I would try running a LED with the 330 Ohm resistor for awhile and if it last do the rest. You could also use a 12V voltage regulator to pin the voltage at 12V. A bit more complicated.
Arjan
Old Feb 4, 2004 | 07:57 PM
amusement's Avatar
Get a potentiometer that can handle 1 amp DC 12 volts 1,000 ohms.
Grab a multi meter
Add power,
Twist pot knob until you see 2.2 volts
Remove pot from power
Take meter and test resistance from one end to the other
You got your resistor value.
Math is good but, pratical works too.
Old Feb 5, 2004 | 06:10 AM
Jason B's Avatar
You could save yourself a little trouble and use regular lights like I did....
One of my favorite mods!
Old Feb 5, 2004 | 07:04 AM
MTL_4runner's Avatar
LEDs sounds like a pretty neat idea since they are very energy efficient and produce no heat.
Wouldn't take many to produce alot of light down there.
Make sure you do a writeup when you finish it.
Old Feb 5, 2004 | 10:50 AM
Erich_870's Avatar
He's right, I have been working on this exact same project, but I went with 4 green LED's to being with. It don't produce enought light. I then went with the expensive SUPER BRIGHT green LEDs, that were 2.85 a pop. These are much better, but only ordered one so far. I'm willing to bet you won't see anything impressive if you don't go with those.
Erich
Old Feb 5, 2004 | 12:55 PM
Highland Runner's Avatar
I am working on LED footwell lights right now. Got the LEDs from Target in the ricer section of the automotive dept. The name on the box is Hikari dash mood light set-cost $10. It has 2 LEDS on 4ft cords with a cigarette plug. Took the plug off and am hard wiring it to the door lights. Each cord has its own resistor built in. The LEDs are mounted on a swivel base with sticky tape. They are very bright.
Old Feb 5, 2004 | 06:01 PM
I used to work with LEDs alot so here are a few pointers:
1) get at least 100 candelas per LED (cheapos and SMTs are in millicandelas) or more
2) power is not an issue but make sure you can supply enuf voltage for driving
3) certain colors are tougher to make that others and are therefore less efficient (ie dimmer)
Brighter - white, yellow-green, yellow, green, orange
Dimmer - Pure red, purple and especially deep blue (because of high wavelength of the light)
For reference:
cell phone backlight -> 5-10 candelas
B/W PDA backlight -> 20 candelas
color PDA backlight -> 50-70 candelas
Notebook display -> 300-500 candelas
Computer monitor -> 1000-3000 candelas
Read more about lighting here:
http://ww2.green-trust.org:8383/lighting.htm
Check out this seriously bright LED (cheap @ $15 for 660 candela!)
http://www.bit-tech.net/review/82/
....or check out these!
http://eng.luxeon.hu/luxeonIII.html
Old Feb 5, 2004 | 06:05 PM
Vato Loco's Avatar
Any pics!
Old Feb 6, 2004 | 06:41 AM
Sorry, no pics yet. I'm still in the middle of wiring to the door lights. It has been pouring rain for the last 2 days so I can't leave the doors open and everthing apart. Maybe I can finish Sat morning.
Old Feb 6, 2004 | 11:08 AM
amusement's Avatar
Sweet mod!
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
RyanJ989
11
Apr 7, 2021 09:41 AM
voiddweller
Sep 28, 2015 11:21 PM
Scotttekoch
Sep 28, 2015 10:30 PM
dropzone
Sep 13, 2015 11:18 AM
