LED 3rd Brake Lights now available for 3rd Gen's!
Old Feb 3, 2009 | 04:42 PM
  #41
DavidAlexander's Avatar
So I already have this LED 3rd barke light installed and I want to get a pair of the LED tail lights now.
Should I just mount one of these resistors on the 3rd brake light wires before I put the LED tails on to stop the ABS light problem?
I wanted to confirm this was the correct resitor for the LED 3rd brake light. ( to get it to work with LED tails)
http://www.v-leds.com/Shop/Control/P...d/0/SFV/32481#
Sorry if I overlooked the answer, I searched and came up with these.
I want some confirmation before I order LED tails. Thanks, D
Old Feb 3, 2009 | 07:23 PM
  #42
JC_ez's Avatar
Hey guys! I made my own LED CHMSL a while ago but never got around to posting pics. I used the stock housing and designed a PCB for my setup. I personally like more densely packed LEDs than the one that is currently being offered for sale. The pictures are taken a bit darker than usual to show more detail. For brightness comparison, I am using the stock 2002 tail lights and during the day, my LED CHMSL is slightly brighter. I hope you all enjoy!
Attached Thumbnails LED 3rd Brake Lights now available for 3rd Gen's!-led-chmsl-small.jpg   LED 3rd Brake Lights now available for 3rd Gen's!-led-chmsl-2b-small.jpg
Old Feb 4, 2009 | 05:20 AM
  #43
Belize Off Road Team's Avatar
It's about time they made one. Now they just need to make an LED 3rd brake light for the 2nd gen.
Old Feb 4, 2009 | 05:40 AM
  #44
Geographeen's Avatar
I am definately putting this one in the pipeline. I am about to install all new LED's for the interior this weekend and was then planning on buying a pair of LED tails. This will definately complete the package!
I'm gonna go with the standard red LED 3rd brake light.
Old Feb 4, 2009 | 06:47 AM
  #45
pdyebrasil's Avatar
I like it! I made my own as well... and I also like it better. Did you sand down the lense at all to get rid of the pillows? I can't tell exactly from the picture... I did that and it looks a LOT better now. Here is a picture before I sanded down the lenses:
Old Feb 4, 2009 | 06:55 AM
  #46
Can You guys running all LEDs confirm this resistor for the 3rd brake light so I wont have ABS issues?
Old Feb 4, 2009 | 06:56 AM
  #47
wyorunner's Avatar
ive got all replacment LEDs for just about everything inside and out, waiting to be installed. i bought the red 3rd beginning of january.
Old Feb 4, 2009 | 07:02 AM
  #48
wyorunner's Avatar
David, i ordered the 6 ohm 50 watt resistors, which is what others have used.
https://www.yotatech.com/forums/f2/a...-tails-128796/
thats basically the reason i bought 6 ohm.
Old Feb 4, 2009 | 12:39 PM
  #49
JC_ez's Avatar
Thanks pdyebrasil! Yours looks awesome too! I didn't sand down the 'pillows', but I designed the PCB so that the LEDs perfectly coincide with the 'pillows'. I like the effect it has on my CHMSL. As you move side to side the LEDs almost flicker, but because of the spacing I chose, still look very uniform.
Old Feb 4, 2009 | 04:08 PM
  #50
Thanks, Ill get those on order.
Old Nov 1, 2009 | 05:25 AM
  #51
Ron Helmuth's Avatar
okay so how many folks are now running these 2 products and how is the long term sealing working out? Still no ABS lights?
thanks for the link up Godzilla
Old Nov 1, 2009 | 10:17 AM
  #52
wyorunner's Avatar
I am running both led tails, and third. Everything seems to be working just fine, or atleast it was when i left my truck back in september. Havnt had any problems with leaking, or ABS, the one time i did have a problem with ABS, i unhooked the battery, let it sit, and hooked back up. Light went away. I never installed the 6 ohm resistors, and things seem to be working like a charm. All my light on the back of my 4Runner are LED, i replaced the bulbs in the reverse and turn signals on the rear. Havnt done the fronts yet, but thats going to be done when i get home.
Old Nov 1, 2009 | 10:22 AM
  #53
Elton's Avatar
i like my the one i made
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
