I've got a rattle
Old Mar 23, 2004 | 01:42 PM
Jonathan's Avatar
Angry I've got a rattle
When accelerating, I hear this rattle coming from what seems to be the exaust(around the cat). It does it in nuetral when I rev it up and through every gear (manual tranny) as I accelerate. I'm thinking it's a heat shield rattle, but was wandering if you guys have had any of these same issues or any other ideas of what it might be. Thanks for any info. Jonathan
Old Mar 23, 2004 | 01:46 PM
AmPm's Avatar
That's that same thing I'm getting and from searching around the site, I think mine is the catalytic converter.
Old Mar 23, 2004 | 01:47 PM
kford's Avatar
I had something like that once, I go mudding a lot and I had some dirt clods up around the cat and around the muffler too. Just clean everything off down there, see if it's still there.
Old Mar 23, 2004 | 02:15 PM
ToyRider's Avatar
Hi
Yes, I had that problem with my toyota pick up, it was the heat shield on catalytic converter too.
Old Mar 23, 2004 | 05:54 PM
Jonathan's Avatar
Ok, well it looks like i've narrowed my problem down to the heat shield then. Guess I'll have to get that checked out. Thanks for the input fellas.
Old Mar 23, 2004 | 06:04 PM
4RUNR's Avatar
Guest
Get a stainless steel clamp ~5" for $3. Wrap it tight around the heat shield and it should be good.
Old Mar 23, 2004 | 06:15 PM
Jonathan's Avatar
Yeah I actually heard about that before; I might give it a try. Thanks for the help.
Old Mar 23, 2004 | 06:29 PM
SIGMAN's Avatar
I Can Not Believe You Asked That Question Tonight. In Just The Last Couple Weeks My 2000 Tacoma Sr5 Has Also Developed A Rattle Coming From
What I Thought Sounded Like An Exhaust Problem.. That Is Really Nice To Know !!!!! I'll Try The Clamp Remedy Also.
Old Mar 24, 2004 | 05:51 AM
CTB's Avatar
CTB
The problem is probably because you go to USC!
Haha...but I did want to ask, how are those brakes and lights working?
Old Mar 25, 2004 | 10:50 AM
SloPoke's Avatar
Rattle???
Yah, like the others stated, it's the heat shield on tha cat. The band trick don't always work either. You see, what happens is that it gets caked in mud. Some falls off and some comes off when you spray underneath (you do clean underneath right?) Then, from jaring and bumping down the road, small pieces fall off and land in the heat shield. Small pieces but bigger than the holes in the shiled. Then they just rattle. Kinda like rocks in a coffee can. Squeazing the can ain't goina keep em from rattlin', follow me? I end up cutting the heat shield off all my cats with my plasma cutter. Wallah, no more rattle.
Here's a pic a few exhaust set ups ago.
Just be sure to not stop long in tall dry grass. The converter gets hot enough to ignite dry grass with direct contact. That's why the heat shields there. If I wan't lazy, I'd fab a removable heat shield. Too much work though.
Happy Wheelin'
ashamsuddin
17
Jul 22, 2024 03:59 AM
gibbonsballer10
Oct 26, 2023 07:13 AM
zytra
Jan 24, 2019 03:16 PM
Corvoid
Dec 11, 2015 11:21 AM
Flightguy
Oct 2, 2015 05:34 PM
