ISR Mod
Old Apr 20, 2003 | 03:53 AM
LSUMatt1514's Avatar
ISR Mod
Are the power gains from the ISR mod worth the extra noise? Someone correct me if I'm wrong, but I get the feeling that things are really, really loud during acceleration with the silencer removed. Has anyone done any dynos on this mod, or is it just seat of the pants feeling at this point? Thanks. Later.
Matt
Old Apr 20, 2003 | 05:50 AM
White SR5's Avatar
Immediate power
Well the ISR was the last mod I did, and although I am going by the "seat of my pants" I know for a fact that the throttle response imprved dramatically. As for HP and torque, again it is not tested, but listen to this. When I got mine done, I thought I'd try it out so I hit the gas full throttle, and guess what -- my rear wheels lost traction! They never did that before, and although it isn't concrete evidence, it was enough to convince me. The ECU has adjusted some since then. I also have the deck plate mod, Amsoil, and a Jardine exhaust system so there was more boost behind that, but before the ISR, even with the other mods my rear wheels wouldn't spin. Think what you like, but I'm convinced!
Zach
Old Apr 20, 2003 | 06:11 AM
Zach,
Just how loud is it? Is it really, really loud or just noticeably louder than the deckplate by itself? If it will provide solid results then I would like to do it, but I also don't want the noise to be unbearable inside the truck during hard acceleration.
Matt
Old Apr 20, 2003 | 06:50 AM
White SR5's Avatar
Talking Hehe...
Heehee, it's hard to say. My exhaust is so loud I can't hear any engine noise under even minimal acceeration. I did only the deck plate before the exhaust and the noise was quieter at idle, louder under acceleation, and quieter at constant speed, but I can't vouch for the ISR. I doubt Dr. Z could either, hehe (he has the same exhaust as I do). Sorry, can't help ya much here.
Zach
Old Apr 20, 2003 | 08:31 AM
vtruong1's Avatar
LSUMATT,
I did the ISR mod, I actually wrote up a little review about it too. Titled "Dr Z MOD", I think. Anyways, to answer you question, when I first preformed the mod, the noise is a little annoying when you ECU is re-learning your new setup. The engine will rev a lot longer until it shifts into a higher gear. This goes for about a week (300-500 miles). But now, it is only really loud if you gun it. I have a stock exhaust.
Old Apr 20, 2003 | 10:44 AM
midiwall's Avatar
One thing about the ISR mod is that it's cheap to do if you use plumbing caps, and because you used plumbing caps, it's VERY easy to put back if you don't like it.
I'd suggest trying it out. I don't find it all that loud... Though I tend to drive with the tunes a bit loud.
TheBFA
Feb 15, 2020 06:55 AM
voiddweller
53
Feb 1, 2016 05:46 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
Boomer8404
Sep 10, 2015 09:01 AM
