ISR Mod
Old Apr 16, 2005 | 04:43 PM
Lone4runner's Avatar
ISR Mod
Wheres the best place to get the tube for the ISR mod? Do I have to got to a muffler shop or can i get it at home depot? and last but not least what are the optoins forgive my stupidity but i cant seem to find the best place to get this. bTW i have a 99 4runner limited 3.4 engine. Have doen many searches but none tell you exactly where. please help : )
Old Apr 16, 2005 | 05:18 PM
JETSI's Avatar
search Airaid MIT.
Old Apr 16, 2005 | 05:27 PM
boy thats expensive
Old Apr 17, 2005 | 08:26 AM
humanoid's Avatar
You could always remove the ISR cap the hole with a PVC end cap, drill a hole for the vacuum tube and you're good to go.
Old Apr 17, 2005 | 09:17 AM
midiwall's Avatar
If you're looking to replace the whole tube, then I got materials from Lowe's - I had problems finding the right sizes at Home Depot. To size things, I pulled the intake in the parking lot and brought it inside. It made things a whole lot easier.
If you're looking to leave the stock tube and just plug up the holes, then I found pieces to fit at both Lowe's and Home Depot. Again, pulling the intake and bringing it in makes things easier.
Old Apr 17, 2005 | 02:17 PM
TACOMANATOR's Avatar
boy thats expensive
Expensive, but its a clean install and takes about 10 minutes.
Old Apr 17, 2005 | 03:28 PM
yeah id like to replace the silencer all together and the reason why im a bit heistant to spend $89 for the airaid is cause im not sure if the sound increase is worth the extra omph. and lowes would have a PVC tube thats about 2.5" ID?
Old Apr 17, 2005 | 04:00 PM
not sure i know exactly what you mean
Old Apr 17, 2005 | 04:51 PM
Its only loud if you have the deckplate mod or have opened up your airbox. If you have the deckplate, you can put it back in and the intake noise will be close to stock. My truck is loud only when i'm on the throttle. Otherwise it is tolerable.
Old Apr 17, 2005 | 05:02 PM
but you dont think its worth it to make it yourself though? im just curious. wont i get the same result? or is it just easier tio install?
Old Apr 17, 2005 | 05:22 PM
You can get the same result if you make it yourself. The Airaid might be bigger in diameter in the middle since it is molded this way.With the tubing it will be the same diameter the whole length. The effects are probaly negligible. Also, since it is molded it has no seams or ribs to obstruct the air flow.
Old Apr 17, 2005 | 05:24 PM
JETSI's Avatar
Took me about ten minutes to install.I don't have the deck plate mod, i just removed the elbow. Mines not loud at all.
Old Apr 17, 2005 | 05:52 PM
Gangus2006's Avatar
I hope you people are not using PVC. PVC releases toxic gases when it is exposed tot he temperatures that exist under hte hood of your vehicle.
DO NOT USE PVC!!!
Old Apr 19, 2005 | 11:46 AM
2001Millrunner's Avatar
I got mine for free! Went to a muffler shop, gave the guy the diameters for both ends. He said i'll try it and said "you can have it" I believe rerouting vacumn hoses for 99+ is easy. I didnt have to get anything else, just route the hoses.
Old Apr 19, 2005 | 12:06 PM
Hawaiian4R's Avatar
Hey 2001Millrunner, when you re-routed your hoses, did you follow this tech write-up? https://www.yotatech.com/~corey/tech...take/albpm.htm
Old Apr 19, 2005 | 12:27 PM
Tacoma Dude's Avatar
I'm seeing a couple takes on the ISR mod in this thread.
The original poster has a 99 runner... I dunno what steps are involved in that ISR mod but I do know that there are some versions where the intake runs through the silencer and another version where the silencer is plugged into the side of the intake.
Talk about a plastic cap vs. a segment of pipe vs. Airaid are going to be confusing if this guy doesn't know which type of intake silencer he has.
Old Apr 19, 2005 | 01:45 PM
my 2001 came with the plastic cap on the intake plenum. so i just pull the hose from the intake silencer and rerouted it to that after i took off the plastic cap. Check the pics on write up and make sure you have the same set up. I'd think on on write up would be more accurate for your application.
Old Apr 19, 2005 | 06:24 PM
sounds like my only choice is the muffler shop huh?
TheBFA
Feb 15, 2020 06:55 AM
voiddweller
53
Feb 1, 2016 05:46 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
Boomer8404
Sep 10, 2015 09:01 AM
