ISR Mod
Old Jul 29, 2003 | 10:56 AM
4RUNR's Avatar
Guest
ISR Mod
Just wanted to share a revelation: a spray paint can is exactly the right diameter for the 3.4 mod. Some cans are better than others as they are made from thicker steel. Just cut it the right size for a total of $0
Old Jul 29, 2003 | 12:38 PM
amorphous's Avatar
krylon!
so, you could have Rustoleum can there!
Make sure you get all the paint propellant out before you saw the ends off the can, folks!
a!
Old Jul 29, 2003 | 12:42 PM
Hyperlite's Avatar
Use a new can and a welding torch
Old Jul 29, 2003 | 01:16 PM
rimpainter.com's Avatar
Or just huff all the paint out before you start.
Old Jul 29, 2003 | 05:14 PM
Albuquerque Jim's Avatar
Well, I have to tell you that I tried that. The cans are way to flimsy once you release the pressure. I actually tried a spray silicone can (waterproofing).
Just get a piece of contractor's grade electrical conduit. In, fact if you pay for the shipping I will send you a piece. I had to buy a 10' section top make mine.
Old Jul 29, 2003 | 11:22 PM
outdoorfever's Avatar
Use a new can and a welding torch.
Lets hope you have to huff that paint before you use the welding torch and paint can.
Old Jul 30, 2003 | 08:28 AM
Hyperlite's Avatar
uh, I used the end cps for PVC pipe, I beleive that there is a write up in the tech section. I just turned the caps around and stuck them in the holes where the boxes were. connect the air hoses to one of the caps a presto, your done (I think the write up uses a plug that is too big, I used a smaller one and used zip ties to clamp down on it.
Old Jul 30, 2003 | 08:35 AM
bamachem's Avatar
99 and up has a different ISR than pre 99's...
Old Jul 30, 2003 | 08:40 AM
Hyperlite's Avatar
:pat: oh yea sorry, but you mignt be able to use part of my idea?:pat:
TheBFA
Feb 15, 2020 06:55 AM
voiddweller
53
Feb 1, 2016 05:46 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
Boomer8404
Sep 10, 2015 09:01 AM
