Interior lighting and dash guages
Old Oct 14, 2002 | 09:28 PM
Sludge's Avatar
I just got some halo reverse indiglo guages from ebay for my 2nd gen runner. Iknow BTOWN4RUNNER aka: Ryan you have them installed on your runner got any tips or tricks for me on the install to make it easier. Also i want to mod my door panel lights, remove the red lense and make/buy a clear one to change the bulb color or install those cheap stobes that ppl put in their headlights.This way ppl will notice when your door is open.
Now about footwell lighting. Does anyone ahve a good suggestion on the lense housing to use in the footwell area so far i have just seen the light and not the unit the light is in.
Old Oct 14, 2002 | 10:29 PM
Bob_98SR5's Avatar
Firefighter:
Here's a write up that UK Meyers did on his 2nd gen that might help you which is in the "Tech" section of Yotatech:
https://www.yotatech.com/~corey/tech...ey_indiglo.htm
Bob
Old Oct 14, 2002 | 10:53 PM
Sludge's Avatar
Hey thanks for the link on that. Seems very easy to do I just hope my indi gauges are cut properly. Plus this give me an excuse to replace some rocker switches with some stock ones from a wrecked runner (moment of silence please):cry:
Old Oct 15, 2002 | 12:56 AM
butnut's Avatar
Hey FF. I mentioned in another thread, my friend made clear green ones out of 1/8" plexi. I assumed he heated the plexi to get the bend. Maybe get the milk white plexi to give a softer white glow. Good luck.
butnut
Old Oct 15, 2002 | 01:11 AM
UKMyers's Avatar
Hey Firefighter I hope that write up helps you out. If you have any more questions on the install PM me or send me an email I'll be glad to help. The only thing I can think of that's not in the write up is that I took out the two bulbs from the back of the cluster to run the wires for the indiglo out the back. You won't need the backlighting anymore and it makes a nice 1/4" hole to run the wires through. Good luck. Be sure and post some pics when your done!
Old Oct 15, 2002 | 04:15 AM
BTOWN4RUNNER's Avatar
Firefighter, congrats on the purchase. You will love them, I do. There are a couple of things that I can think of. When I put mine on, I had to drill a hole for the pin, just like Joey had to. Also, the gauges are somewhat thick and the needle actually rubs on the gauges, so what you have to do is get some thin sandpaper and sand down the bottom of the needle base (black round thing) where it meets the gauge pod, so that it does not rub the face. If you understand that, that is great, I just don't know how else to describe it.
Joey said that he doesn't use the original bulbs, but I do. If you don't, you can't see the trip miles or vehicle miles gauges in the dark. Plus, I tapped into the stock power to run it. When you take the back off, you will see a crap load of wires. Get/borrow a multimeter and figure out which one powers the stock gauges and tap into that. Also, there is a grounding post on the back too, use that and you don't have to run any wires anywhere but to the back. The grounding screws is labeled GND. The only problem that I have found from running the power from stock is that when you mess with the round knob to adjust the brightness of the stock gauges, it will draw power from the reverse indis. Just kinda get the stock light until you can just see it and they turn the gauges all the way up and it is perfect. If you know what I mean.
I apologize for the confusing explanations and the lack of pictures (hopefully getting a digi cam for Christmas). If you have any questions, concerns, etc, please PM me. Goodluck. :fireman:
P.S. I see that you are a firefighter, so am I. What type of trucks does your company have?
Old Oct 15, 2002 | 09:02 AM
Stump1883's Avatar
Hey FF, could you post a picture of what these Halo Reverse Indiglo's look like, I realyl want a set and I'm just not sure what they look like so when I look around Ebay I can make sure to get the right ones. Thanks man.
Old Oct 15, 2002 | 09:49 AM
pfdaxe's Avatar
Seems to be a few firemen on here....
:fireman:
Old Oct 15, 2002 | 11:23 AM
Jason B's Avatar
I added footwells in mine.
Shoot me an email and I can send you the full install write-up. Some more info in my "advice" section on the site.
Old Oct 15, 2002 | 12:37 PM
Sludge's Avatar
Stump1883 here is the ebay link from my auction http://cgi.ebay.com/ebaymotors/ws/eB...tem=1867846210
JasonB what type of light housing did you use for the footweel lights I just need a general idea of what im looking for.Also do you know if anyone makes a replace lens for the doorpanel lights in the 2nd gen Im looking for a clear one so i change the bulb color
Ryan
Thanks for the info on your install and i do understand what you mean about the needle base also i will send a pm on the rigs we have along at the fire station along with some pics if i can find them.
UKMyers
thanks for that heads up on the lightbulbs for the guages i will try it both ways with and without the bulbs.
You guys are great with all the info and help I love it here
Old Oct 15, 2002 | 02:27 PM
Thanks for the future info.
I also want to add that probably the most important thing is that you use some good double-sided tape. That is important, or the faces will come off. Goodluck and let me know how you make out. Thanks. :fireman:
Old Oct 15, 2002 | 02:48 PM
UKMyers's Avatar
Btown I only took out the bulbs that backlit the gauges. I still have the others so that my needles and odo light up at night
Old Oct 15, 2002 | 04:25 PM
Oh, ok, sorry Joey. I thought that you took them all out. My apologies. :fireman:
ashersullivan88yota
Jan 18, 2022 05:37 PM
jasonty
41
Dec 23, 2018 01:00 PM
ViperTT
Aug 14, 2015 05:27 AM
TDonkey
Jul 26, 2015 10:14 AM
HookahRoo
Jul 20, 2015 07:06 PM
