immobilizer? '02 Runner starts w/ "plain" key
Old Feb 9, 2006 | 05:42 AM
forcleanh2o's Avatar
Hi all. My recently purchased a used '02 4Runner only came with 2 plain silver (copy?) keys. In other words, it doesn't have the large black base (where I assume the chip would be). The keys start the truck fine. I guess this means I don't have the immobilizer or whomever owned it or a dealership bypassed/removed/hacked the system? I also didn't get a control for keyless entry (assuming it came on the SR5). An alarm installer told me that sometimes dealerships/wholesalers will bypass the system if they did not get (or lose) the "main" key. I'm not sure. All I know is I'm using the plain silver key to unlock and start/drive.
Any ideas? I'm thinking I'll buy an alarm, that way I'll have the keyless entry feature and an alarm.
I thought all these had the immobilizer.
Old Feb 9, 2006 | 05:56 AM
ecchamberlin's Avatar
I went to Home Depot to have an extra key made for my 01 Runner and it works just like the factory one. I think it was an option.
Old Feb 9, 2006 | 05:59 AM
lee's Avatar
lee
ditto.
Old Feb 9, 2006 | 06:32 AM
Thanks lee and ec.
Any ideas on the keyless entry? Was it standard or option on the SR5? What do you have?
Old Feb 9, 2006 | 06:49 AM
lee's Avatar
lee
id bet you have it... i have keyless
search and youll find instructions for programming a new one.
Old Feb 9, 2006 | 06:54 AM
Toyofast's Avatar
It probably didn't come with the system.
A dealership will not bypass the immoblizer system, it'd be too much work. Cutting a key takes 2 minutes and programming takes about 15-30 minutes. At work we are always making keys for the sales people since they tend to loose them often. The money just comes out of the salesmans pockets. Plus I have no idea how you'd bypass the system unless you'd want to spend $2000 on a new wiring harness.
The factory setup will run you about $400 installed... any aftermarket system will be near the same I believe.
Nope. Not even all the '05 rigs come with them. A simple check with any dealership can tell you what came stock with the rig. I run VIN numbers all day long to check for rigs with or without the immoblizer system when making keys for the sales department.
Old Feb 9, 2006 | 06:59 AM
Thanks for the input! Toyofast- I thought the same thing when the guy said they reprogram for no chip. It sounded too intensive. Thanks again.
Lee- I'll also search for programming keyless.
Old Feb 9, 2006 | 09:06 AM
surf4runner's Avatar
i just pay about $1 more for the plastic part on the key. no immobilizer on mine.
keyless entry off ebay, reprogrammed, works
Old Feb 9, 2006 | 09:09 AM
bigacuralvr's Avatar
From what I understand, the Imobilizer was standard on all 99-up Limiteds, and an option on all others. My sisters 01 SR5 doesn't have imobilizer, but does have keyless. Wish I didn't have that stupid system...costs too much for a spare!!
Old Feb 9, 2006 | 09:32 AM
My 01 SR5 has the keyless. I bought a new fob thing off ebay but they sent me the wrong directions to program it. I sat in the driveway for about 45min trying to do it before I read the top of the directions that were for a camery. It is the correct unit w/rear window button. So I have not programed it yet.
Old Feb 9, 2006 | 10:52 AM
I called Toyota...
Update- I called Toyota and also looked up my 2002 specs here:http://www.toyota.com/html/tcuv/broc...02_4runner.pdf .
It turns out the Limiteds had the immobilizer and it doesn't list it as an option for SR5s. Keyless entry was standard on all. I ordered a remote from "thepartsyouneed.com" ($34.99 after shipping) as others here have done. I checked Ebay, no big savings and questionable return policies.
Old Feb 9, 2006 | 11:06 AM
grimpy's Avatar
from what I recall, big is correct... all 99 and up limited's came with the immobilizer. The eBay immobilizer keys work fine btw... I believe I purchased mine from a seller keysandlocks or something similar to that.
Old Feb 9, 2006 | 01:09 PM
me too. I paid $17 for mine...but just a PITA for programming...
Old Feb 9, 2006 | 05:45 PM
read my last post #21 https://www.yotatech.com/forums/show...=keyless+entry
83yotastockR
11
Nov 10, 2015 06:54 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
PNW94Runner
Sep 29, 2015 02:55 PM
JamesDINAN
Sep 22, 2015 05:37 AM
xzen73x
Sep 14, 2015 03:00 AM
