Im confused about sizes here
Old Dec 23, 2007 | 08:59 PM
Dare44's Avatar
i know it says in the door but im confused, on my 1997 it says it has 15x7 rims and 225 tires, i have 16x7 rims and 265 tho, and they look stock and i didnt think that 15" rims fit over the brakes on the 3rd gens? so whats the actual stock sizes
Old Dec 23, 2007 | 10:36 PM
Dare44's Avatar
i cant believe that no one knows this come on guys i did the search and couldnt find it whats the sizes that were stock?
Old Dec 23, 2007 | 10:50 PM
Elton's Avatar
the door jam sticker is useless the 16x7 was a option added from the dealer
Old Dec 23, 2007 | 10:52 PM
Dare44's Avatar
well im confused cuz my mom followed me on the freeway today and i got cussed out cuz she said that i was speeding all the way home and i was going the speed limit by my speedo
Old Dec 23, 2007 | 11:40 PM
DeathCougar's Avatar
I *believe* that all 4runners say 15" and 225 tires.
The 16" option wasn't always added on at the dealer, it was a stock thing since the brakes were larger on the 16" rimmed vehicles.
Old Dec 23, 2007 | 11:41 PM
Dare44's Avatar
so was the 265 stock tire with those and the speedos corrected for the bigger tires?
Old Dec 24, 2007 | 02:45 AM
One_96TR4's Avatar
These the 265/70/16 is the stock size and teh speedo should be correct. Some ppl on here though have said that there speed was actually corrected when uping the size to 265/75/16. I have found that my speedo now reads correct as well with the 265/75's.
Old Dec 24, 2007 | 06:46 AM
fullmann's Avatar
I just replaced my 265/70-16 with some new 265/75-16 nitto's, and my speedo is spot on according to gps and various speed displaying signs along the road.
Old Dec 24, 2007 | 08:02 AM
AxleIke's Avatar
Our 97 came stock with 16's and 265/70.
It lists a 16 inch rim and 265/70 on the door jamb sticker.
The speedo was dead on before the larger tire sizes.
Your truck came stock with the small stuff. The big stuff was added later.
Old Dec 24, 2007 | 08:09 AM
ninjarunner's Avatar
my door stiker said 15 in rims as well but mine never had them. it was just a generic sticker, it even was wrong with gear ratios.......... dont trut everything you read on a sticker...
Old Dec 24, 2007 | 11:26 PM
Dare44's Avatar
ok well went and looked at the sticker on my moms car and her car has different size tires than stock, she just got new tires so makes sence, so thanks for the info, shouldnt toyota try to make those stickers right cuz thats kinda important
Old Dec 25, 2007 | 03:46 AM
KdF's Avatar
KdF
http://www.discounttire.com/dtcs/infoTireMath.dos
Use the calculator to see the actual speedometer difference.
Old Dec 25, 2007 | 10:33 AM
Dare44's Avatar
nobody has answered weather the 265's were stock or not, if i get another ticket my license is gone so i would like to know how fast im going cuz i like driving
Old Dec 25, 2007 | 11:07 AM
seanz0rz's Avatar
Guest
my door sticker also says 15 inch wheels, but i know that is a lie, because i definitely have the larger brakes.
check to see which size brakes you have, do they just clear the wheel, or is there quite a bit of gap.
really only the base model 4runners came with 15 inch wheels (non sr5) and maybe very few sr5's in 2wd.
i cant tell you whether or not yours came stock with the 265/70r16 tires. one way you might be able to tell is by doing this:
find your REAL ACTUAL gear ratio in the rear diff. search on here on how to do it exactly, but basically mark the dshaft, mark the tire, with one tire in the air, rotate tire 20 times and count the dshaft revolutions, divide by 20 and you have your ratio. you can also get the axle code off of your door, compare it to this chart, and find the ratio you have. though that chart is quite ambiguous.
here is the chart:
http://www.sonoransteel.com/Toyota_axle_codes.html
it is also possible someone in the past has regeared your 4runner. i do not know whether you are the original owner or not. this is why it is helpful to actually count the revolutions
also, speedo's are allowed to report speed 3% higher than actual speed, but cannot report a speed less than the car is traveling. (this keeps you going at or below the speed limit)
Old Dec 25, 2007 | 02:51 PM
Whitey13's Avatar
This has been answered several times in the thread. The 265's were stock on the 16's.
Old Dec 25, 2007 | 06:01 PM
AxleIke's Avatar
x2 ...........
Old Dec 25, 2007 | 09:19 PM
Dare44's Avatar
ok thank you guys, i figured they were stock today when i made several passes by a chp radar trailer thing and my speedo matched what it was saying guess my mom needs to get her acura recalibrated. thanks again guys u guys are awsomen
smilen724
13
Nov 8, 2015 04:11 PM
Gravel Maker
RuffStuff
Oct 4, 2015 10:26 AM
oldblue
Sep 28, 2015 04:07 PM
gp66
Sep 14, 2015 12:10 AM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
