Last edit by: IB Advertising
Browse all: Toyota 4Runner Transmission Guides
- Toyota 4Runner 1996-2002: How to Change Automatic Transmission Fluid
Step by step instructions for do-it-yourself repairs.
how do you change your transmission fluid the easy way ?
Hi, I searched and I found lots of threads regarding the transmission oil change, flush out 100% of the old fluid from the tranny using machines, etc. and a lot of confusion there. What do you guys do to make life easier for tranny oil change if you don't have the machines or if you want to do it yourself ? I know doing oil change, differential oil change, and coolant change, those are pretty straight forward. You just drain the old fluid out and then refill with new fluid. As for the transmission, it is not the same. When you drain the old fluid and refill with new fluid for the tranny, you are only replacing about 3 quarts with new fluid, there are about 13 quarts of old fluid (if I am correct) still sitting in the torque converter and the rest of the tranny system. What do you guys usually do in tranny oil change ? do you just drain and refill about 3 quarts of new fluids every 15K or you would do a complete 100% fluid exchange every 30K with flushing machine ? also, Toyota says that there is no filter in the transmission on the 3rd Gen., but Gadget says there is a filter. Do you guys actually replace with new transmission filter or you don't ? This transmission oil change got me confused. thank you for your input
My understanding is that there is no filter (I was wrong as Jaime has pointed out. There is a filter, just not one that you replace.), just magnets in the pan that require cleaning. There is a thread here on how to do a transmission flush the old fashioned way but I searched and I can't find it. MTL4runner and Nrgetic are two people that come to mind that really understand ATF and related maintenance.
You can always go to a shop that has a machine but I'm sure you know this. Good luck.
To answer the question, yes there is a filter screen, but filter is serviceable/cleanable so no need to replace it (which is probably why the dealer guys said there was none (this is not a part they usually even carry). I usually just clean it with brake cleaner when I drop the pan (you should clean the magnets in the pan too).
Here is what it looks like:
The owner's manual says that if I just perform a "drain and refill" on the tranny, it's 2.1 quarts. Is that a typo ? you said about 3 to 4 quarts and I heard most people said about 3 quarts. I want to make sure I will buy enough transmission oil to do the drain and refill.
For what it's worth, the machine flush guys claim the screen filter is automatically cleaned of metal particles and other gunk with the flush itself.
I called several places local to me, including the stealer, and no one drops the pan and cleans the filter. This is the method preferred by Gadget.
So I will do the flush every 45k-50k miles where the rig pump does the work, and let my local shop do the flush. Sounds pretty messy to attempt at home.
BTW - I will be using Amsoil ATF.
From Gadget's site (on cooler line flush which supposedly cleans the filter):
"The other thing I do not like about this type of flush is that they sell the supposed benefit that they do not have to drop the pan and change the filter like that is a benefit. Dropping the pan is very important. Looking in the pan is a fantastic diagnostic tool that can tell you if something is going wrong in your transmission. Now lets say some crud is flushed out of the trans with this flush method. Where does it go? It can go into the pan, and then sucked up into the filter that may clog the filter causing the pump to starve for fluid and a pressure loss. On the engine the filter is after the pump and if the filter gets clogged there is a bypass valve that opens and oil bypass the clogged filter so the engine is still supplied with oil. Unlike the engine oil pump and filter the filter is on the intake side of the pump. If it gets clogged, that is it, it is clogged and stuff does not get lubricated and the clutches do not get enough clamping pressure and they slip and burn up. In just a faction of a second you just bought a new transmission if the filter clogs."
Gadget does go on to say on his site that the filter should always be replaced but I absolutely disagree with him there (which I rarely do). The screen/filter is a very fine metal mesh which can be reused (after a thorough cleaning) many times without needing replacement. Bottom line is you should ALWAYS drop the pan about every 50k to clean the filter and ensure all is well with your transmission.
Jamie,
There was a thread here about an online manual for 1997-2000 Toyota trucks. In that manual, it says that whenever you remove the pan, you need to realign (after cleaning) the magnets in some specified location (dimensions were given). Is that true? How difficult is it to do it?
Thanks.
Thanks.
Originally Posted by RoySharif
Jamie,
Thanks.
Thanks.
Here are the magnets in the pan:
http://aarc.epnet.com/application/93...MENDATIONS.htm
That is a link that should get you to an online service manual. I can't get to the exact page, so you will have to click on the table on contents to go to the page relating to transmission service.
It has information related to magnent placement.
I am not sure which tranny it refers to since I have only seen the 4 magnet pan mentioned (where indents are in pan).
Anyone care to comment on this?
Which trannys require magnet precision?
i went to napa the other day and asked about a tranny filter and pan gasket and they sell the kit for $20. so why not drain your pan and install a new filter? is there any other way to drain all of the fluid, other that a flush?
I have seen several kits for the fliter and none had a filter as well built as the OEM version. I was ready to change my filter too the first time I pulled the pan (I had kits from Napa, Checker and Autozone since they all looked slightly different), but after comparing the two, it seemed a waste to burn $20 for a fliter that could easily be cleaned and reused (the entire filter is metal, both the body and the screen). I have already reused the same filter 3 times after cleaning (about every 50k) with absolutely no issues.
Originally Posted by bamachem
After reading thru it, I might just tackle the flush myself.
The problem I was having was finding a shop that did the Gadget preferred flush so I was ready to settle on the flush without dropping the pan.
Anyone have a good cleaning procedure once the pan is off?
It sounds like rags shouldn't be used?
What seals are required to be replaced?
the1998sr5
Jul 16, 2015 06:20 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
