Holy SAS!!! (ebay)
Old Nov 21, 2003 | 06:26 PM
joshik's Avatar
Holy SAS!!! (ebay)
doodes, these are rad! i need my truck to look like these!
here
here
Old Nov 21, 2003 | 06:37 PM
scott.475's Avatar
Oooookay, but only if you promise to never, ever take it off road, because driving over anything more than a small speed bump in either of those would result in massive body damage to those nice poser rigs There is a lot to be said about motion, not just size....you know what I mean! Flex and tire size!
Old Nov 21, 2003 | 06:42 PM
Vato Loco's Avatar
These are just show trucks right?
Old Nov 21, 2003 | 06:48 PM
Jonathan's Avatar
Hahaha yeah i don't think those fenders would like those tires if the truck happened to flex
Old Nov 21, 2003 | 07:11 PM
Vato Loco's Avatar
Kind of a waste of money on the front SAS if you ask me.
Old Nov 21, 2003 | 07:43 PM
WATRD's Avatar
I like the second one...
4 cyl engine, 4.11 gears and 44" tires.
0-60 in 12 days... I am thinking it might be a bit under geared...
Old Nov 21, 2003 | 07:55 PM
mtnkid85's Avatar
*CAUGH* CHEVY 350 *CAUGH* excuse me.
Old Nov 21, 2003 | 07:59 PM
WATRD's Avatar
Mileage: 154000 VIN: 4TARN13P2RZ218551
Get the Vehicle History Report
Number of Cylinders: 4 Type of Title: Clear
Transmission: Manual Interior Color: Gray
Warranty: None Exterior Color: Silver
Standard:
4 CYLINDER 2.4 LITER
Optional:
MANUAL 4 WHEEL DRIVE AIR CONDITIONING AM/FM RADIO
CD POWER STEERING
I guess there is a bit of conflict with his description... Even so, 4.11 and 44's is a bit of a stretch even if the 350 part is right.
Old Nov 21, 2003 | 08:00 PM
kyle_22r's Avatar
you could always pop the t-case in low range to try and get it started with those gears...might result in a little grinding when you try and go back into 4hi though
that rear on the second truck doesn't look like a dana 60 to me though...looks like a gm corporate 12 bolt
HiLux_1990's Avatar
Does anyone know what these two 'features' are on the first truck?
New dual 2 1/2" thru bed exhaust system.
Rear mounted radiator.
Thanks.
Old Nov 21, 2003 | 08:41 PM
scott.475's Avatar
Thanks.
Look at this pic and you will see both.
Exhaust is run upright like that so that it doesn't go under water, which could cause water to get ingested into the engine if the engine dies while the exhaust is submerged (Hummers/HMMVs have this feature). Behind the exhaust pipe you can see the radiator mounted at an angle. A lot of desert/pre-runner type racers do this so that the radiator isn't damage by flying rocks and hard landings. In this guys case, it would be so he doesn't loose cooling ability when those huge tries rip out his front end when he runs over a cat
Old Nov 21, 2003 | 10:29 PM
toy283's Avatar
Why even shift into high at all? Scott@Rockstomper leaves his front case in low all the time. Four cylinder engine (now a 1.9 liter Saturn, but a 22R before), 44" Swampers, and 4.11 gears. Does just fine up to ~55mph.
I also have a rear-mounted radiator and have been strongly considering running the exhaust there too. Fording 40" water can be a PITA if you stall with the exhaust any lower. Everything else is already set up to ford water that deep.
Old Nov 22, 2003 | 07:23 AM
Shane's Avatar
Those actually look alot like the two trucks a guy on the PBB owns, AFAIK the only thing they ever see is mud.
Old Nov 22, 2003 | 08:21 PM
HiLux_1990's Avatar
Thanks scott.475.
Seems like an awful lot of work to plumb the radiator out the back.
I've actually seen a few traybacks here that have an upright exhaust... usually it's just because they're trying to make their little rig look like a big rig!
Old Nov 24, 2003 | 12:18 PM
Baja racing trophy trucks have the radiators and electric fans in the back. They'd be clogged with dirt so quickly if they were mounted in the front that the trucks would overheat. Cooling is pretty important when you're running through the desert at high speeds.
See pics here. Also, here's a sweet Prerunner'd 4Runner for sale
http://www.desertspeed.com
Old Nov 24, 2003 | 03:46 PM
joez's Avatar
if you switched the two trucks tires they would make more sense. the first one is definately set up for mud, and only mud. minus the tires of course. the second one doesnt even have a front driveshaft. and i doubt that 81-83 front axle is gonna hold up to a 350 and 44's.
kawazx636
Oct 6, 2021 03:03 PM
Iceman4193
Oct 16, 2015 10:50 AM
irv
Sep 29, 2015 01:04 PM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
