HELP! Security Light
Old Dec 26, 2004 | 06:55 AM
etgunner's Avatar
Unhappy HELP! Security Light
Hey guys, I posted a question the other day via the phone and a friend. I was on vacation in North Carolina and my truck would not start one morning. I noticed the security light on the dash was still flashing after I put my key in the ignition. Is this normal?
I am back in Florida but my truck is still in North Carolina. Any help is greatly appreciated. Could my truck not starting be related to that light flashing? I cannot remember for the life of me if it is supposed to go out after inserting the key. I have an extra key that I can overnight to the garage if that could be the cause.
My truck is a 99 4Runner 4wd limited.
Thanks!
Old Dec 26, 2004 | 12:19 PM
etgunner's Avatar
Bump:
Anything on this guys?
I am going to fly up to Asheville, NC tomorrow morning with my spare key in hopes my truck will start.
Old Nov 6, 2006 | 06:49 AM
jtrent's Avatar
I am having the EXACT same problem. Any updates on what caused/fixed this?
Old Nov 6, 2006 | 06:56 AM
86SR522REEFI's Avatar
Do you have a remote? There should be a green or red button you can press that will let you start it. Other than that im stumped
Old Nov 6, 2006 | 07:12 AM
jtrent's Avatar
86SR522REEFI:
My remote only has lock, unlock, rear window, and panic. No remote start features that I'm aware of. The problem is intermittent, and most of the time it works fine. But especially when it's very cold, the security light still blinks after unlocking the truck with the fob and inserting the key into the ignition. If the security light doesn't go off, the truck won't crank...if it does go off, the truck cranks every time with no problems at all.
Old Nov 6, 2006 | 07:13 AM
04 Rocko Taco's Avatar
did you just unlock it with the remote, or did you unlock with the key? Its something with the security systemin the car, the sensor says your theft deterrent is still 'armed' or what have you, so it keep your car from cranking. I had a similar problem on an 03 S10.
Old Nov 6, 2006 | 07:26 AM
jtrent's Avatar
I've tried it both ways. Something with the cold weather is causing the immobilizer system to not recognize my keys...none of the 3 work.
Old Nov 7, 2006 | 08:48 PM
dizzmann's Avatar
my 97 taco alarm was blaring at me last week when i reconnected the battery. the alarm has been disabled for years.
the engine woudl not start so i turned the key from off to key on, not start , between 3 and 5 times. then from off to start.
if the red light is blinking , on my taco i can push the red light, its a button. i push it a few times too while going from off to key on.
Old Nov 7, 2006 | 09:06 PM
CJM's Avatar
CJM
If its the factory system you turn the key really quick a few times, my camry was this way. It would disable if you did a sequence with the key on and off and pushing a little button.
Old Nov 8, 2006 | 09:01 AM
jtrent's Avatar
The 99+ 4Runner Limiteds all have this "immobilizer" system it seems. Unlike other Toyota vehicles, there is no button or apparent way to bypass a malfunctioning system.
Old Dec 29, 2006 | 06:19 PM
jtrent's Avatar
Oddly enough, I think I've got etgunner's old rig. Anyway, it looks like it's the ECM, and it's gonna take about $1500 to find out for sure... =(
okamikai
Apr 30, 2018 10:19 PM
AkitaDog
Sep 1, 2015 08:05 AM
shisha1999
Aug 14, 2015 01:33 AM
PopsDad1
Jul 30, 2015 02:21 PM
sabine
Jul 18, 2015 03:59 PM
