HELP: no brake lights
Old May 4, 2004 | 07:37 PM
BLKNBLU's Avatar
Everything else works back there. Parking light, tail light, turn signals, reverse lights. Unfortunately, I don't know how long this has been this way so I can't say if it is related to other activity under the hood. But it has been a long time since I've done much of anything under there except oil changes. Fuses are good, bulbs have been replaced (even though i didn't think it was that) and as I noted, every other light back there works. The haynes manual shows the taillights on a 15A circuit, but I don't have a 15A circuit. That's in the under hood fusebox. Am I missing something? Secondary fuse, relay, switch... something? I hate electrical stuff.
Old May 4, 2004 | 07:45 PM
bike4miles's Avatar
Replace the brake fuse just for fun (sometimes they go bad and they look good) and check the sockett with a test light for starters. Then I would try checking the wires to see if the insuation has won through anyware causing a short circut. After that??? That's about all I can think of.
Old May 4, 2004 | 08:06 PM
BLKNBLU's Avatar
thanks. will do.
Old Jun 27, 2004 | 11:30 PM
88-4RUNA's Avatar
did you ever fix this problem? IF so what was the cause im currently having this same issue.
Old Jun 28, 2004 | 04:09 AM
HondaTec521's Avatar
Two words , "TEST LIGHT "
Old Jun 28, 2004 | 04:53 AM
X-AWDriver's Avatar
Check the bulbs to make sure they are seated properly,I had the same problem with everything working fine but no brake lights and it was just that the bulbs weren't pushed all the way in. Doh!!!
Old Jun 28, 2004 | 09:17 PM
88-4RUNA's Avatar
I have a test light but i dont know exactly which fuse is for the brake light, my fuse cover is missing and my service manual doesnt show what each fuse is for. I checked all fuses under the dash visually and they all look good.
Whats the purpose of the switch near the bottom of the emergency brake? My manual makes no mention of it, and when i release my emergency brake it doesnt even touch it.
Btw Hondatec521, would you happen to be a member of honda-tech.com?
Old Jun 28, 2004 | 09:42 PM
zach34's Avatar
Yeah, just make sure everything is pushed all the way in. I had the same problem on my truck.
ashersullivan88yota
Jan 18, 2022 05:37 PM
fountain
Dec 31, 2015 06:08 AM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
