help
Old Jun 29, 2004 | 04:23 PM
chasmc2's Avatar
Unhappy help
Well I don't know where to start first. I had a sh%$$& day. I crushed my exhaust pipe. I had to drive it to get to a place I could cut it. Did I hurt anything????? I drove as slow as I could.
Second. My passenger side cv came lose from the diff. Not sure what is up. I slipped it back in but, what is the cause.
Then I blew a belt and while I was under looking at the cv I saw coolent leaking. Still trying to find it. Please some one help im very sad
Old Jun 29, 2004 | 04:40 PM
gumbo's Avatar
Whoa stop take a breathe! The exhuast pipe is not hurt. Do you mean the cv boot? I'm sure others will chime in. Try to sit back and relax for awhile. I feel your pain.
Old Jun 29, 2004 | 10:38 PM
chasmc2's Avatar
I will make this a little more detailed. The axle came out of the diff about 1/4 to a 1/2 inch. I popped it back in by hand. the cv boots are fine. I was out in the rocks and went up on an embankment on the passenger side. this was the same side the axle came out. just wondering what is going on. I have done alot of off camber driving and have never had this happen. Just looking for some one that has had there rig that far apart. I haven't had the pleasure yet. It does seem the way its going theres something that is going to have to be fixed. and about the coolent. I ran out of sun light and time. I'll look at that in the am. I just din't like seing it drip from the front rim ofthe oil pan and the engine.
thanks in advance.
Old Jun 29, 2004 | 10:41 PM
96LtdYota's Avatar
sry for your troubles.... man you had a hard one
Old Jun 29, 2004 | 11:21 PM
jimbo74's Avatar
if you were in a very rough section while offroading, it is very possible that you could have jsut overextended the cv and that now that its back in, nothing is hurt... you might want to check your diff fluid level however, not with all cvs, but with some, depending on their construction/manufacturer, they might leak fluid if the cv is popped out..... the cv popping out isnt a normal thing, but can be justified as you were wheeling in a manner not normal to what the rig usually or was intended to see....
Old Jun 30, 2004 | 08:53 AM
chasmc2's Avatar
Yea I have a very large Puddle on my drive way,and I hate the smell of gear oil.
Old Jul 1, 2004 | 08:03 AM
chasmc2's Avatar
is there anything on the inside of the diff to hold the cv in or is it being held in by the way the cv is wedged between the wheel and the diff????
Old Jul 3, 2004 | 01:42 PM
chasmc2's Avatar
can someone please answer
Old Jul 6, 2004 | 07:28 PM
chasmc2's Avatar
ttttt
Old Jul 6, 2004 | 07:57 PM
OneTrickToy's Avatar
Not sure with the diff. I have yet to take mine apart(will do soon). But about your exhaust. If you don't have any emmisions laws in CO, then do what I did. Cut your exhaust parallel to the ground, right at the body line. It will keep your exhaust pipe out of sight and safe from rocks.
Old Jul 7, 2004 | 08:50 PM
chasmc2's Avatar
already cut the pipe just really wondering about the cv and diff. is there anyone out there that has had there diff taken apart? and if so is there anything holding the cv in?
Old Jul 7, 2004 | 08:56 PM
88yotaboy's Avatar
Which side did it pop out from? If it popped from the side that goes into the wheel and hub assembly you could have popped this little butterfly washer deal off that holds the axle in place. If that is the case then you will need to take apart your hub and put it back on. Hope i helped.
Old Jul 8, 2004 | 03:55 PM
chasmc2's Avatar
the cv came out from the diff side not the hub side.
Old Jul 8, 2004 | 04:04 PM
oly884's Avatar
Guest
I can assure you that there is supposed to be something that holds the CV axle in the diff. It sounds like something is broken, but the nice thing is, at least your 4wd works so it can't be too bad.
Old Jul 8, 2004 | 05:16 PM
chasmc2's Avatar
yea im hoping that someone can tell me what to look for before i rip the diff out. not looking forward to it.
thanks for the info everyone so far.
I'm going till i get the bad news or I can hope good news
