Heater core question
Old Aug 30, 2004 | 08:25 PM
the_supernerd's Avatar
I just purchased a heater core for my truck, but it looks different from the heater core in the repair manual. The one in the repair manual has long pipes coming off of it, while mine only has small ones. It looks like longer pipes could fit in the outlets with seals or solder or something, so I am wondering if I need to purchase some seals or solder or anything like that to attach the pipes to it.
Old Aug 31, 2004 | 10:34 PM
Anyone ever done this before or have any ideas if I need anything for it? The link below is the one I bought.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33548
Old Sep 2, 2004 | 10:22 AM
SuperDuperDave's Avatar
I would think that as long as the pipes are long enough to fit the hose and a hose clamp you should be okay. I did mine a couple of years ago, but can"t remember.
Old Sep 2, 2004 | 03:13 PM
I do not think that these pipes are nearly long enough. They are only about an inch or so, while the picture in the manual has long pipes. It looks like a pipe could fit in those inch long outlets, but it does not say anything about it in the book.
Old Sep 3, 2004 | 07:03 PM
Babypig's Avatar
There should be extensions already in the truck that go on to the heater core leads. What kinda truck is this for?
Old Sep 3, 2004 | 08:16 PM
I am putting the core in a 1987 4x4 standard cab pickup.
Old Sep 4, 2004 | 05:28 PM
I am sure the extensions are there, but I just want to know if I need to buy a new seal or solder or something to attach them to the core.
Old Sep 6, 2004 | 03:29 AM
HiLux_1990's Avatar
As has been suggested, it looks like your heater core uses two extension pipes that go through the firewall. You'll see how it all works when you remove the HVAC system from your truck.
What you need though is a couple of O-rings. Your Toyota dealer should be able to look up a diagram on the computer showing the connections from the heater core and any O-rings you'll need.
While you're working on the aircon/heating, have you considered upgrading to the new gas?
Old Sep 6, 2004 | 11:45 AM
Thanks for the info, that is what I needed to know.
I would, but I do not have A/C.
the1998sr5
15
Jul 14, 2020 08:35 PM
94 Newbie
Aug 6, 2015 10:33 AM
this_guy
Jul 31, 2015 01:27 PM
jjrbus
Jul 19, 2015 02:06 PM
msane99
Jul 17, 2015 10:13 AM
