Heat/AC Controls Don't Light Up
Old Jan 30, 2003 | 04:59 PM
sworxx's Avatar
I have a 97 T100 Extra Cab SR5 4x4. The heat/AC controls do not illuminate at night. Kind of a pain. I test drove a 98 T100 and it also had the same thing. Cooincidence? Did Toyota forget to light up the Heat/AC controls? Or do I have a bulb or fuse out that I can't see? There is no mention of it in the owners manual. Any help is appreciated. Thanks.
Old Jan 30, 2003 | 05:29 PM
L33T35T 4Runner's Avatar
I have the same problem in my 95 4runner. When i got the car (4 months ago) they never lit up. ever since then ive seen them light up ONCE.
they should light up... keyword being "should"
Old Jan 30, 2003 | 05:32 PM
Shane's Avatar
Not sure about the T100 but in the other older rigs there's a tiny very fragile bulb behind the HVAC controls, mine was acting up and to get it to light I had to smack the top of the dash. I swapped it out with the one from the glove box (same bulb in '86) and works normally again.
Old Jan 30, 2003 | 05:54 PM
sworxx's Avatar
Sure doesn't look easy to get to behind that panel?
Old Jan 30, 2003 | 05:59 PM
Shane's Avatar
On mine you yank off the knobs and then pop out the face, not sure if it's the same for you...
Old Jan 30, 2003 | 06:37 PM
Corey's Avatar
Co-Founder/Administrator
2nd gen 4Runners & '89 to '95 trucks are the same.
http://www.pnw4runners.net/tando/tips.htm
It's easy to do as Shane said.
Remove knobs from heater sliders, put in a paper clip and gently pull from the sides as to not crack the panel.
Once in there you will see the magifier lens for the bulb.
Pull it out, and don't lose the green condom.
Toyota will charge you a few bucks for the bulb.
Take the bulb to a local auto parts store, and get it for under a $1.
Old Jan 30, 2003 | 06:45 PM
Shane's Avatar
Nah, toss the condom as well as the ones behind the dash, bareback all the way. Much brighter without and a heck of a lot easier to read.
You mean you actually found that bulb somewhere other than the Toy dealer?!?! I looked high and low and nobody had that tiny little bulb anywhere so I gave up on replacing the one I stole from the glovebox, never needed it anyways.
Old Jan 30, 2003 | 07:11 PM
Corey's Avatar
He he, bareback...
The Auburn Auto store (ASAP) right down by Pizza Hut here has the bulbs in stock.
Old Jan 30, 2003 | 07:24 PM
Shane's Avatar
I'll have to stop by there next time I'm in the area, thanks for the info.
Old Jan 30, 2003 | 09:11 PM
well.. i just swapped the light from my glove box to my ac controls... and i didnt put the green condom back on.... i like it brighter
here are photos of me doing it... 5 in all
knobs simple pull off....
http://66.75.118.29/light1.jpg
using any flat utensle (sp?) pry the face plate off... it seems fragle... and CAN break... but its quite flexable.. to a point. at this time the A/C button comes out...
http://66.75.118.29/light2.jpg
front face removed...
http://66.75.118.29/light3.jpg
picture is of removal of magnifier thingy for the light... simply pull back clip with one finger (on right side) and pull out unti with small screw driver or finger from top
http://66.75.118.29/light4.jpg
mag. removed.... bulb exposed. you can simply pull it out with your hand.
http://66.75.118.29/light5.jpg
to remove the glove box light, unscrew the 10mm bolt bottom right of glove box, unscrew 3 screws inside top glove box, latch glove box closed. unccrew last screw bottom left outside glovebox. support bottom of dash with hand, open glove box. let hang
i put the condom on the light then pulled it out with needle nose pliers... but if you have small enough hands im sure you can fit your fingers in there and remove the bulb
i just put the condom on the broken light and put it back in the glove box light holder. put everything back together, works great! ...atleast the a/c light works great, glove box light is broken now
oh ya... sorry for the blurry pics. there was very little light in my car so the camera couldnt focus at all.
Old Jan 30, 2003 | 09:16 PM
Corey's Avatar
Excellent
You know, I was thinking about pulling mine off tomorrow and taking pics on how to do this.
Would you consider having me put this up as an article here?
That way it will be on the Tech page for future reference.
We get a lot of inquiries on this very topic.
All I would need is the text sent to me in a doc format, or WordPad, and tell me where to insert each picture.
Old Jan 30, 2003 | 09:17 PM
Shane's Avatar
Cool, so my half-assed method worked for you too!
Old Jan 30, 2003 | 09:37 PM
Re: Excellent
sure. i'll make the document tomorrow... MS Word fine?
I could also put it on my tripod site... http://l33t35t.tripod.com
id be glad to make the document myself.... I didnt take microsoft office for two years for nothin
I'll also take some better pictures... when its light out
what size would you like the pictures? i took those at 640x480 in low quality. I can go up to 1600x1200 in super high quality...
I have a canon A40 2.0MP
its so nice
Old Jan 31, 2003 | 01:27 AM
dave jamieson's Avatar
Climatic control lights
Hey Lads,
just fixed my heater control lamps. If you have the Climatic Control Type VS the manual control, two green Pea lamps are located in the rear of the digital screen. Email me with replacement how to at dave.jamieson@sympatico.ca for a 4 runner. Everything unsnaps. The only screws are for the climatic control unit.
dave
Old Jan 31, 2003 | 04:53 AM
Corey's Avatar
640x480 pics are what we use here for the tech write-ups most of the time.
I like to host it on the server here, but you can also mirror it on your site if you want to.
I like to host the stuff here as a lot of time I have noticed that some sites are down from being overloaded, or someone who runs a home server has their PC turned off.
No one can see the information then if they go to look it up.
Word doc would be fine, but the pics would have to be seperate as I have no way to extract them from a document.
Just Zip them up, or send them all at once to my email listed in the sig above.
Thanks, Corey
Old Jan 31, 2003 | 05:01 AM
billyho's Avatar
I have a '97 Tacoma and mine went out two weeks ago. Goto the dealer and pick one up for about 3 bucks. If yours is like mine you will have to pull the knobs off of the a/c heater controls and then take a small screw driver and pop off the plate. Under that plate is a clear plate the will come off and the bulb is behind there. It was very easy to do. Let me know if you have any questions.
Old Jan 31, 2003 | 03:45 PM
sworxx's Avatar
Wow, thanks for the help! It's much more info than I even needed. I'll try it tomorrow. Thanks again
Charecter1
Nov 6, 2023 10:08 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
coryc85
Sep 9, 2015 06:24 AM
Sep 4, 2015 09:27 AM
madxman21
Jul 9, 2015 10:26 AM
