headlight issues
Old Sep 25, 2017 | 11:09 AM
ronyag's Avatar
headlight issues
headlight will not shut off
Old Sep 25, 2017 | 11:31 AM
akwheeler's Avatar
Hammer time!
It sounds like your headlight switch is jacked up, but I don't know if you are talking about a vacuum cleaner, a motorcycle, maybe a golf cart? does your rig have daytime running lights? is this with the key off as well? have you waited like 5 minutes and they are still on?
Throw us a bone here and help us help you.
Old Sep 25, 2017 | 08:16 PM
RAD4Runner's Avatar
What year Escalade?
A problem well-stated is a problem almost solved.
If asking for help, always indicate model-year-engine-transmission-trim. Best to put it on your signature to save everybody time.
Originally Posted by akwheeler
Hammer time!
It sounds like your headlight switch is jacked up, but I don't know if you are talking about a vacuum cleaner, a motorcycle, maybe a golf cart...
Sounds like the switch too, or a hammered relay LOL!
Old Sep 26, 2017 | 04:48 PM
akwheeler's Avatar
Then again, I always find it helpful to write my questions in a message, stick it in a bottle and send it floating through cyberspace and forget about it.
Old Oct 1, 2017 | 09:07 AM
TheDurk's Avatar
These are a pain. You will have to do some circuit testing to chase the issue. The DRL system is super complex if that is what you have. In addition to stalk and relay, issue can also be in the Combination Switch (Dash cluster in Toyotaspeak) where the auto-off control resides. If it's a 4Runner, I can tell you how to do it, IF I knew the year and whether DRL or not. If a Taco, hopefully someone else can do it.
You really need to specify the vehicle IN DETAIL to get help on electric.
Does the auto-off work when you turn off the key and open the driver's door? Are you sure it's not just DRLs?
eutahg
May 8, 2017 05:40 PM
Lochsa
Apr 3, 2017 09:39 AM
mrmike210
Mar 31, 2017 05:48 PM
SO TEEN
Mar 25, 2017 03:08 PM
DuB
Sep 16, 2003 03:57 PM
