glass paint?
glass paint?
well i just got my autodim mirror installed, and i cant stand seeing the button, and the big piece of the mirror mount. is there any special glass paint, the kind that the manufacturer uses, that will adhere better than spray paint? i tried spray paint, but it will not hold on enough to hold the mirror. i know that newer cars with this type of mirror have paint to block out the button.
im just talking new cars in general, i saw some that had that black paint type stuff, like whats on the edges of the glass. behind the mirror mount. Do the new t4r's have autodim/compass mirrors stock, do they just show the mount through the glass or have it blocked out?
If you can get your hands on a spot sand blasting gun your could mask off the area, blast it lightly to leave a slightly rough surface which should enable any subsequent paint to adhere well.
The gun type with the rubber cup for blasting spot rust should be ideal as it won't throw sand all over your interior.
Originally Posted by lee
wait, wont that make the windsheild crack in very cold temps?
it shouldnt be a problem, but if you want, just cut the piece out of the tint where the mirror adheres (do a test fit with it all.) if your worried about edges, make the cut-out slightly smaller then the mirrors surface, at least 90% will be in contact with the actual glass
*edit* lol, i see that you are trying to hide that piece though...
seems like the tint and etching are my best two options. is there any such thing as something like a transparency but with adhesive on one side? That way if i went with the etch, i could cut out the pattern before i put it on the windshield, then just peel off the back and stick it up there.
Go to the tint shop and get an estimate. Theyll do a good job and it wont be much $$$ or time fartin around with a "sand blaster".
They make a windshield 4" tint roll that you can get at PepBoys or WallyWorld for like 7$ if you gotta do it yourself
I dont need to tint the top of the windshield, theres already the toyota tint there. All i need is the darkest tint behing the little mounting plate/button for the mirror. so i can easily do it myself
Most craft stores sell etching kits with a mask that adheres to glass and the etching gel. My wife has made some custom flower vase designs using it. It's easy to use and should put just enough 'tooth' on the glass to accept paint. However, I'd try the 'reversable' tinting option first.
Thats a good idea, but on the autodim mirrors, the part i am trying to hide is way bigger than the actual mounting button. Im just going to go get some tint at walmart or try to get a scrap at a tinting shop around here. I really dont need a whole roll.
ashamsuddin
17
Jul 22, 2024 03:59 AM
PNW94Runner
Sep 29, 2015 02:55 PM
