Gas leak when filling tank
I have a 99 4Runner Limited and had some frame rust repair few days ago,they had to take the gas tank down to do repair and last night i went to fill it up and it leaked gas when it got full.from searching around here i think it may be the filler neck.maybe when they reinstall the tank didn't install the filler neck correctly.I wanted to ask for you guys opinion before i try to crawl under and take a look.if that's the problem can it be fixed without removing the tank?can i see where the neck connects to the tank without removing the tank? Also on my way home from work today CEL came on,is it related?
Well that pretty much says something is not connected or tightened
Most often when I need to drop a tank I loose and disconnect at the gas cap side of the filler neck.
Did you pay for this repair???
Then have them make it right if it was a freebie you might ask for help and offer some thing they might want.
Bottom line something got done wrong putting the tank back in.
Might not be to some a big deal gas fumes a spark very big deal Even Diesel fuel .i would hate to have to pay for a new quickie Mart if it was only the gas pumps:jessica::jessica::jessica:
skoti89
Sep 11, 2015 07:46 AM
pyramid
Jul 30, 2015 10:05 AM
