Gas leak when filling tank
Old May 10, 2013 | 10:53 AM
edgar62902's Avatar
I have a 99 4Runner Limited and had some frame rust repair few days ago,they had to take the gas tank down to do repair and last night i went to fill it up and it leaked gas when it got full.from searching around here i think it may be the filler neck.maybe when they reinstall the tank didn't install the filler neck correctly.I wanted to ask for you guys opinion before i try to crawl under and take a look.if that's the problem can it be fixed without removing the tank?can i see where the neck connects to the tank without removing the tank? Also on my way home from work today CEL came on,is it related?
Old May 10, 2013 | 11:20 AM
vital22re's Avatar
totally a bro
More than likely they damaged a vent hose for the evap system. That will trigger the CEL and could cause leaking if you overfill.
Old May 10, 2013 | 12:14 PM
edgar62902's Avatar
just got home from auto zone and cel code is P0440
Old May 10, 2013 | 02:22 PM
wyoming9's Avatar
Red face
Well that pretty much says something is not connected or tightened
Most often when I need to drop a tank I loose and disconnect at the gas cap side of the filler neck.
Did you pay for this repair???
Then have them make it right if it was a freebie you might ask for help and offer some thing they might want.
Bottom line something got done wrong putting the tank back in.
Old May 11, 2013 | 02:35 AM
edgar62902's Avatar
That's Exactly What I Was Thinking,Yes I Paid For Repair And Will Make The Fix It,Thanks Guys
Old May 11, 2013 | 04:17 AM
Ipaman's Avatar
On most cars The filler neck gets tightened down with clamps. They probably forgot to tighten one. Not a big deal.
Old May 11, 2013 | 05:33 AM
wyoming9's Avatar
Red face
Might not be to some a big deal gas fumes a spark very big deal Even Diesel fuel .
i would hate to have to pay for a new quickie Mart if it was only the gas pumps:jessica::jessica::jessica:
Old Jun 6, 2013 | 06:12 PM
edgar62902's Avatar
it's fixed,went to my friends garage and he took the tank down and found a hose disconnected.don't know wich one but a case of beers took care of that.thanks guys
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
skoti89
Sep 11, 2015 07:46 AM
pyramid
Jul 30, 2015 10:05 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
