Old Apr 5, 2016, 08:36 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Exterior Guides
Print Wikipost
gas flap won't open
Old May 3, 2004 | 07:04 PM
RufusRunner's Avatar
gas flap won't open
I have a '95 4runner, and when I pull on the little thing to open up the gas flap, it doesn't do anything. This is the first time it hasn't worked and its a pretty big problem considering I drove home (about 15 miles) on empty, and It's hard to fill up when you can't get to the gas tank. Has this happened to any of you before? suggestions? any help would be appreciated. Thanks.
Old May 3, 2004 | 07:21 PM
Scofco's Avatar
When mine is sealed with ice or mud, I'll have someone pull the handle while I pry open the little door with a pen or something. Do that to get in and figure out what the deal is.
Of course if a cable rusted through that won't work
Old May 3, 2004 | 07:22 PM
good thinkin, I'll see what I can do, thanks.
Old May 3, 2004 | 07:37 PM
jethro's Avatar
Yeah that happened to me once while I was at the gas station. I had already pre-paid, so it was a pretty big problem. I know I looked like an idiot, but after about 5 min. it just popped open. Hasn't happened since, but I now carry a flathead screwdriver in the console just in case.
Old May 4, 2004 | 01:25 AM
Corey's Avatar
Co-Founder/Administrator
Yep, happened to me at work about 3 years ago.
Luckily member Toddski came over to my parking spot later and stuck a credit card in the door while I worked the pull lever.
You can bend out that steel spring some also to give it more "spring."
Also put some grease on it.
Old May 4, 2004 | 05:22 AM
Highland Runner's Avatar
It happened to me once also, but after I had worked under the dash. The cable had slipped out of the little handle and I didn't know it untill a week later when I went to fill up. You should be able to get to the release if you take the right rear interior panel out. Kind of a pain but if the cable broke it may be the only way.
Old May 4, 2004 | 08:22 AM
KING's Avatar
If what I am understanding, I had a similar problem about two months ago.
When I would stick the key in the gas tank door, the key would not turn.
I found out it was my key and it was too worn out. I went to TOYOTA, picked up a new one and a wahala, it works perfect now.
Old May 4, 2004 | 08:46 AM
flecker's Avatar
From: White Mountains, Arizona (Yes it does snow in AZ)
Next time it sticks... leave it. You'll save about $40 bucks!
Old May 4, 2004 | 01:11 PM
bike4miles's Avatar
LOL Mine was stuck when I first got it but I have since (fater gluing the door back on the hing with JBwled) gotten into the habit of lubing the mechanisms with light oil about twce a year and it works smooth as butter.
okamikai
Apr 30, 2018 10:19 PM
Doug4320
Mar 24, 2018 10:11 PM
skoti89
Sep 11, 2015 07:46 AM
pyramid
Jul 30, 2015 10:05 AM
daddio
Jul 18, 2015 10:20 AM
