Fuel Injector Removal Pictures (How To)
Old Jul 10, 2016 | 07:34 PM
  #41
TboneRare's Avatar
Originally Posted by post office
Throttle body will have to come off. You need access to the bolts to remove the fuel rail. IMO it would be much more difficult to *attempt accessing the injectors with just the throttle body off, than removing the plenum. I have done mine three times (unlucky injector man). After you do it once, its a no brainer doing it again. There's a few tricky spots but its not bad.
Replace O rings definately. The three times i had to replace an injector i just re-used them all. The last time i started having them stretch out and tear. When that happens you 1. have fuel leaking everywhere. 2. Have to repeat the entire job after re-assembly. 3. When you repeat the job, you're basically huffing gas for as long as it takes you to do it. In my experience, i was huffing gas for about 45 min.
That makes 4 times i have replaced an injector. # 4 was simply because i thought, "hey i've reused the O rings three times now, lets go for 4.)
Fuel is flammable. Engines create heat. If you're lucky it will just be an inconvenience.
Or.
I've posted this question in a number of forums and decided that it would be best to have all of the injectors professionally cleaned and flow tested. Also, replace all seals, gaskets and fuel filter while I'm at it. Short cuts have a habit of backfiring.
And thanks for all the advice.
XtraCab
Apr 12, 2020 05:25 AM
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
Sep 4, 2015 09:27 AM
karbin
Jul 5, 2015 11:37 PM
