Fuel Injector Maintenance
Old Jan 29, 2015 | 07:49 AM
oregon taco's Avatar
What (if any) is your fuel injector maintenance protocol?
How many miles/years do you have on your fuel injectors?
In those miles/years, how often (if ever) have you had them professionally cleaned? Replaced?
Do you use fuel injection cleaner? What kind? How often?
Old Jan 29, 2015 | 08:34 AM
JasonYota's Avatar
Interested in this as well.
Just hit 90k in my DD, nothing has ever been touched. I might try a bottle of injector cleaner next tank, see if it helps my fuel mileage.
Old Jan 29, 2015 | 07:21 PM
Flame Thrower's Avatar
FormerVendor
well, the strongest injector cleaner and your best bang-for-the-buck is redline si-1 injector cleaner. it has the highest concentration of polyetheramine (PEA) and it's what i recommend. use it every 10k miles and you should be OK.
Old Jan 31, 2015 | 06:23 AM
ThorInc's Avatar
I'll have to try this next for preventative maintenance I have been running the Lucas with some decent but unverified results. Still working on the Lucas gallon so it will be a while still.
Old Feb 1, 2015 | 09:07 PM
maachine's Avatar
i usually throw a can of seafoam into my tank every other oil change. just for preventative maintenance. my truck has 155,000 miles on it and no issues yet
Old Feb 8, 2015 | 06:29 AM
aowRS's Avatar
322,700 on the original injectors. Never touched. I typically dump a bottle or two of Techron in every year. That's it. Starts, runs and stops like it did in 2001.
Andreas
Old Feb 8, 2015 | 11:31 AM
skypilot's Avatar
I use Luca's by the gallon. Good stuff. I did a tear down on a 5.7l SBC and it was very clean below the injectors. That however did not save it from a stuck exhaust valve.
Old Feb 8, 2015 | 03:40 PM
cep89's Avatar
215,000 on the original injectors. A bottle of techron in the tank and run it out before the oil change. The engine runs very strong.
Old Feb 18, 2015 | 11:08 AM
alsanpedro's Avatar
1998 SR5 4x4 3.4L 172K
I had my injectors serviced at 160k trying to get rid of a miss at idle that wasn't throwing a missfire code. Here's a link to the company. http://www.rceng.com/Fuel-Injector-Cleaning-P43C0.aspx
There was an improvement after cleaning. But the true cause was the coil packs.
Old Feb 19, 2015 | 06:29 PM
YM13's Avatar
I'm currently running a can of Seafoam through the tank and some through the crankcase which has worked well for me in the past but I had no specific complains from my injectors – just doing some spring cleaning. I'm looking into and will probably try out Royal Purple's cleaner:
Amazon.com: Royal Purple 11722 Max-Clean Fuel System Cleaner and Stabilizer - 20 oz. Bottle: Automotive Amazon.com: Royal Purple 11722 Max-Clean Fuel System Cleaner and Stabilizer - 20 oz. Bottle: Automotive
I am very impressed with RP's products and the reviews are outstanding for that specific product.
Blamalam
Mar 12, 2022 07:34 AM
RatOmeter
Oct 22, 2015 03:17 PM
Tacoma1313
Aug 17, 2015 05:44 PM
pyramid
Jul 30, 2015 10:05 AM
HookahRoo
Jul 20, 2015 07:06 PM
