fuel gage frozen at way over full
Old Jul 17, 2006 | 03:18 PM
bflooks's Avatar
hey guys. i am getting ready to go to paragon, but i have an issue with my fuel gauge. it is stuck WAY up past full, and i have tried to way overfill it to get the float to drop down, but it hasn't worked. anyone else have this issue? it happened while wheeling the crap out of it on a full tank in the rocks. i will drop the tank if need be, but i just thought i would ask before going in to it.
thanks!
Old Jul 17, 2006 | 03:27 PM
ilikesoup's Avatar
It might seem like a stupid thought... but have you gone under the vehicle and kicked the tank real hard trying to free it?... closest thing that happened to me was I rolled the runner with a trailer, and it jacknifed and dented my fuel tank, and now it goes down to 1/2 a tank when it's empty. (still haven't fixed that )
Old Jul 17, 2006 | 03:34 PM
bflooks's Avatar
i have tried everything i could, but it is still frozen. i will yank the tank, but figured i would as for other options incase i missed something.
Old Jul 17, 2006 | 03:38 PM
Elton's Avatar
i would clean the inside of the tank while you have it out
Old Jul 17, 2006 | 04:00 PM
bflooks's Avatar
i was thinking the same thing actually! at 162k, it should probably be done. lol
Old Jul 17, 2006 | 04:01 PM
Tanto's Avatar
You may want to skim through this thread about a similar issue...
https://www.yotatech.com/forums/f2/3rd-gen-fuel-gauge-problem-i-think-i-figured-out-problem-pics-60260/
Old Jul 17, 2006 | 04:06 PM
bflooks's Avatar
yeah, i read that thread.
but that was for the inaccurate reading.
mine was fine until i went wheeling.
Old Jul 17, 2006 | 05:29 PM
oly884's Avatar
Guest
maybe the gas fairy is being extra nice to you!
Haha, really though, pull out a multi meter and check for any signal. If you have a FSM or know someone that does, take a look at the trouble shooting section, sounds like it's either toast or a wire is messed up.
Old Jul 18, 2006 | 06:04 PM
heddleston's Avatar
I have the same issue...except mine was stuck on "E" with the light on (for a day) and then it jumped to full and has not moved from that position.
I slammed the gas tank hard and bent it and the skip plate. I am curious as to how to fix it. I have not dropped the tank yet but I think thats what is going to happen. If you do this before me please keep us up to date on YT. Thanks,
Jonathan
Old Jul 19, 2006 | 08:56 AM
ilikesoup's Avatar
Jonathan
Ditto... if you drop your tank and get a dent out of it, I'd like to see how it's done... mine is pretty bad, and the driveshaft only clears the skid plate by about 3 inches now because of the dent. Although, better my skidplate, than a hole in my gas tank
Old Jul 19, 2006 | 11:40 AM
Ironmike4x4's Avatar
I have not dealt with a Toyota unit yet, but they work relatively the same. There have been cases where the "fingers" on the resistor for the level have been stuck in one area of the potentiometer. You might could bend it back just a little, but if you are in the area you might as well buy a new sending unit just to prevent a future problem anyways. Also I have seen a few cases where the wire connectors going into the pump itself were burnt or corroded making a false reading.
Old Jul 19, 2006 | 11:51 AM
bflooks's Avatar
i have not had a chance to pull the tank yet. i figured i would start with the plug/connctor first, and cleaned it up really nice, but no go. i will have to hook up the meter to it, and then....after paragon apparently, i will have to drop the tank and replace the su.
bigjstang
Jun 2, 2025 03:56 PM
jerusry
Oct 19, 2015 05:28 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
redneck17
Jul 17, 2015 07:44 PM
Jonny246
Jul 12, 2015 04:51 AM
