First Oil Change!
Old Sep 20, 2002 | 07:57 PM
amdman's Avatar
First Oil Change!
Well guys I just got done changing my oil for the first time. Switched it all out for M1 Synthetic Oil, but I do have one question. In the manual it says to add 5.5 Quarts of oil.... when I look at the dipstick it is only half way between both lines. Is this ok? Not that big of a problem? Oh yea and that oil filter was a pain in the ass to get off.
Thanks for your help guys.
Old Sep 20, 2002 | 08:01 PM
Churnd
Guest
Posts: n/a
the manual estimates how much oil you will need. sometimes you'll need more and sometimes you'll need less. just make sure the dipstick reads full. add more until it gets there.
Old Sep 20, 2002 | 08:53 PM
Bob_98SR5's Avatar
amd:
just as churnd says, you might need to add more or less, depending on the dipstick reading. i would add though that if you are checking the oil temp while the engine is cold and NOT idling, go on the low side of the range b/c when your engine heats up, the oil will expand from the heat. You can test this by checking your oil in the morning...and later when you get home and shut off your engine after a long day's drive.
Bob
Old Sep 21, 2002 | 12:30 AM
Robinhood150's Avatar
You didn't say what year or which engine you have, but I've heard that on the 3.4Ls you can reach through the wheel well and grab the oil filter that way. Supposed to be much easier.
Steve
Old Sep 21, 2002 | 07:30 AM
Hbum's Avatar
5.75 qts. fills mine to the line.
Old Sep 21, 2002 | 05:35 PM
mogwai snot's Avatar
I have had several representitives from Havoline and Toyota visit our dealership and they really stressed to all of the technicians to not use synthetic oil until new cars have reached 10,000 miles. Just a little FYI.
Old Sep 21, 2002 | 08:14 PM
kctopher's Avatar
Co-Founder/Administrator
What?? I have put full syn in since the first oil change....
First oil changes are always a pain in the head, they freaking put those filters on with a freaking impact wrench on the production line.... ughhh, maybe not but a pair of channel locks are a MUST foe the first oil change!!!
Old Sep 22, 2002 | 04:53 AM
amdman's Avatar
Hehe Well mine is a 2000 SR5 with 66700 miles on it so it wasn't the first first oil change, just MY first oil change to it. lol but that damn filter was on there tight as hell it was pissin me off.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
horunner1x
Jul 10, 2015 06:33 AM
