Expert Needed Power Steering Confused!!!
Old Feb 5, 2005 | 01:04 PM
Teamsobaco's Avatar
Hey guys,
I am having a major PS leak. This is not the pump or resivor the previous owner replaced those. The leak come from a "BOX" on the lower passager side. This "dox" is mounted directly to the frame. The local parts place and the FSM nor the Haynes shows this box. What the hell is it? I lnow that the PS lines go into it however it appears that some other line run through this thing too. I tried taking it of to look at it What a bitch...I abandoned the project due to lack of line wrenches. I observed a little plastic piece on the bottom of this box where the PS is leaking from. Someone please give me a clue to what this is and if there is a rebuild kit avalable. For the experts...here is the VIN JT3VN39W4R0146743
Old Feb 5, 2005 | 01:07 PM
terryjmatthew's Avatar
Assuming it is a 2nd Gen, It sounds like the power steering gearbox?
You should be able to get a reman unit from a parts house (Carquest,Autozone, etc).
Old Feb 5, 2005 | 01:10 PM
Teamsobaco's Avatar
not gear box
this is a 94 2nd gen the gear box is on the other side this box is on the passanger side...
Old Feb 5, 2005 | 01:12 PM
Got any pics?
Old Feb 5, 2005 | 02:45 PM
Teamsobaco's Avatar
Bump
Bump to the top
Old Feb 6, 2005 | 07:07 AM
Teamsobaco's Avatar
No one else has this thing in their truck?
Old Feb 6, 2005 | 08:11 AM
mt_goat's Avatar
Did the PO do something custom maybe? Do you have an idler arm on the Pass side? Let's see pics!
Old Feb 6, 2005 | 08:52 AM
4Crawler's Avatar
The box on the passenger side is for the ABS brakes. It uses the power steering fluid to actuate the ABS.
Old Feb 6, 2005 | 09:54 AM
Del's Avatar
Del
So if the power steering fluid is low, would that cause any problems with the ABS? Mine seem to lock up rather quickly on slick or even slightly damp roads, and I know I have a power steering leak somewhere also.
Old Feb 6, 2005 | 10:35 AM
4Crawler's Avatar
Not sure, never had ABS myself, but one sure way to find out. Dump some ATF in there (not power steering fluid) and see if it gets better. May also be the load sensing proportioning valve on the rear axle. If you have the classic 4Runner "butt sag", then that fools the LSPV into thinking there is a ton of weight in the bed and it increase the rear brake pressure to compensate. However, if there is not really weight back there, that could make the rear brakes more prone to locking up.
Old Feb 6, 2005 | 04:53 PM
Teamsobaco's Avatar
Great thank you now we have established it is the ABS system..does anyone know how much it costs to rebuild/replace...this might expalin why I have to STAND on the breaks.
Old Feb 13, 2005 | 04:33 AM
Teamsobaco's Avatar
bump for help
Old Feb 13, 2005 | 06:34 AM
4Crawler's Avatar
Do you have a local Toyota dealer? Might be worth a stop there to get an estimate on the repair. Do you have a local brake shop? Might be worth a 2nd estimate there. Or try a junkyard (http://www.car-part.com/) and see what the going price is for that part.
voiddweller
19
May 2, 2016 09:10 PM
yourrealdad
7
Jul 21, 2015 08:53 AM
Bamripzit
Jul 19, 2015 01:17 PM
Bamripzit
Jul 13, 2015 07:21 PM
1badyota350
Jun 28, 2015 06:50 AM
